Stopping Vibration
Old Feb 10, 2008 | 09:42 PM
lurtonk's Avatar
lurtonk
Default Stopping Vibration
I did a search but didn't see anything on this so here is my problem:
When I am stopping, especially while sitting in traffic, right before the C6 stops i feel a vibration. It is not coming through the steering wheel but I seem to feel it through the seat. The pulses are always the same duration regardless of the speed. I don't notice anything when coming to a complete stop from 15 mph and faster only when I am stopping from slow speed.
My C6 is as automatic, stock tires, wheels and brakes.
Old Feb 10, 2008 | 11:09 PM
99FewteRC5's Avatar
99FewteRC5
Does it feel kinda like a bucking motion with light brake pressure? Your rotors are most likely slightly warped thats why you dont feel it in the steering wheel. Most of the time its just the frt but it can be both frt and rear.
Old Feb 11, 2008 | 06:25 PM
TCW's Avatar
TCW
St. Jude Donor '06-13,'16-'17, '19
It sounds like brake pad material build up on your rotors. On an open road run up to about 90 and do about 3 hard stops. That will probably wear off the pad build up and fix your problem.
Tom
Old Feb 11, 2008 | 06:59 PM
lurtonk's Avatar
lurtonk
Tom
I do hard stops on a regular basis, so that is not it, also there is no squealing.
It is not warped rotors because the pulses are 5-6 per second and the car only moves about a foot. I can almost make it vibrate sitting still.
Old Feb 12, 2008 | 11:13 AM
JLargo's Avatar
JLargo
Automatic or manual? Does it feel like you are running over a steel grate in the road?
Old Feb 12, 2008 | 12:43 PM
stabori's Avatar
stabori
St. Jude Donor '08
1st gear in the transmission maybe
Old Feb 12, 2008 | 02:16 PM
JLargo's Avatar
JLargo
If it is an auto it could be the torque converter.
Old Feb 13, 2008 | 11:16 AM
lurtonk's Avatar
lurtonk
The steel grate is probably the closest to describing the feeling.
Old Feb 16, 2008 | 05:38 PM
Wayne O's Avatar
Wayne O
CF Senior Member
It's extremely unlikely you have 'warped' rotors. Certainly try bedding your brakes. I wouldn't just go up to 90 and slam on your brakes....here's a link with information on how to properly bed your brakes:
http://www.zeckhausen.com/bedding_in_brakes.htm
Inspect the rotors on both sides looking for build-up, scoring and possibly even cracking. You might try scrubbing your rotors with a red (delicate) Scotch Brite pad and possibly use some disc cleaner as well. If you see 'excessive' buildup on your rotors you may have glazed your brake pads (although I think you'd notice that at higher speeds as well).
Ultimately, if the problem persists, take it to the dealership. Good luck.
Old Feb 16, 2008 | 08:20 PM
PowerLabs's Avatar
PowerLabs
From: Greater Detroit Metro MI, when I'm not travelling.
If you park your car after a hard stop that got the braking system very hot, the rotor will cool down unevenly because of the added heat capacity underneath the caliper. This can cause warpage and/or additional transfer of brake pad material. My guess is this pulsation is a brake issue and it is probably related to the explanation above.
I would try to bed in the rotors and pads again (several hard stops followed by a cool down period while driving) to see if that solves the problem.
To Stopping Vibration
