Problem Any Help??????
Old Jun 7, 2008 | 10:18 AM
rockstarZ06's Avatar
rockstarZ06
Default Problem Any Help??????
I changed the plugs and wires last night and now I am getting a charging system error message. I did notice that one plug wire was touching the main wire that comes off the alternator so I moved that and it is still giving the message.
Any Ideas????
Old Jun 7, 2008 | 10:21 AM
calemasters's Avatar
calemasters
Make sure the new ignition wires meet the GM specs for EMI, and that they are "fully" seated at both the spark plug and the coil ends.
Disconnect the battery for 1 min., then reconnect and try again.
Old Jun 7, 2008 | 10:27 AM
rockstarZ06
Put the stock wires back on and it does the same thing. I will try the computer reset.
Old Jun 7, 2008 | 02:26 PM
rockstarZ06
Nope didnt reset with the battery
Old Jun 7, 2008 | 03:49 PM
Walt White Coupe's Avatar
Walt White Coupe
Unrelated. Just because an event precedes another does not mean the first caused the second.
Old Jun 7, 2008 | 04:00 PM
Tag_sk's Avatar
Tag_sk
Default Service charging system message
I recently had the Service charging system message on my 05 C6 A4. I took it in and the low freq horn was changed (it blew the fuse) and they also changed the negative battery cable for corrosion.
Old Jun 7, 2008 | 07:31 PM
rockstarZ06
I think this has to be. I car has under 10,000 miles and was fine as I drove all day let the car cool down, changed the plugs and started it and the message was one. Didnt even drive anywhere.
Is it possible that the plug wire laying on the alt wire fried the alt?
Old Jun 8, 2008 | 12:56 PM
rockstarZ06
UPDATE...
Had the battery and the alt tested and both are fine.
I am lost....No one has seen this?
Old Jun 8, 2008 | 01:44 PM
knkali's Avatar
knkali
I am undergoing this problem as we speak. Dealer replaced the alt-no joy
Spinmonster suggested raising the idle rpm 75rpm
Old Jul 11, 2008 | 07:44 PM
knkali's Avatar
knkali
new PCM= no joy
raising rpm= no joy
New battery= no joy
at dealer but they are stumped.
5v from PCM as should be to signal alt to charge at idle but when attached to alt the volts on the L terminal wire drop and fluctuate between 1.3 and 4.7 v and alt does not charge at idle. Checked wire L terminal between pcm and alt and it seems to not be shorted. I guess they need to recheck everything because this cannot be that hard. Maybe the circuit back to the PCM is the problem?
any help?
Old Jul 11, 2008 | 11:33 PM
knkali's Avatar
knkali
ttt
To Problem Any Help??????
