Headers Vs. 4:10 Gears???
Old Jun 28, 2008 | 08:25 PM
xstang's Avatar
xstang
Originally Posted by welcome2try
Nice video, your mph indicates low 11 second potential .
True...
I'm hoping to hit 10s in my 08... I ran 11.7 with a CAI only, and I'm adding headers next week.... I also added a 3200 converter and Drs...
Old Jun 28, 2008 | 08:38 PM
welcome2try's Avatar
welcome2try
From: Objects in your mirror are losing , Long Island, NY
St. Jude Donor '08
Originally Posted by xstang
True...
Post up your new times with the headers...
Old Jun 28, 2008 | 09:20 PM
NYC6's Avatar
NYC6
Originally Posted by Craigster05
I have 4.10s, here's what I see MPG with mine:
Video
I can take you for a ride anytime for you to see up close, we only live 1 town apart.
I've done some more performance mods since then, added a cam, L92 Heads and L76 manifold. Even with the extra 80 or so HP, the gas mileage and drivabilty with the 4.10s is still amazing. Check out this other video.
Like I said Im not sure on gas mileage drop with shorter gears, but I would be suprised by only a 1-2mpg dip. Ive seen higher than 32mpg on my DIC and I wouldnt use that as a legitimate barometer of actual mileage.
On a side note Ive been following your latest tranformation with interest and looking forward to the dyno results. Im getting itchy to make a decision on which way to go with my car. I missed you last time I was at Elite. My car has a date Tuesday with Kevin and Ritchie for my brake swap. Maybe I'll meet you and your car then.
Old Jun 28, 2008 | 09:31 PM
hognutz's Avatar
hognutz
I think both mods do well on this praticular car.
gears usually help you fuel economy around town. so if you drive mix sometimes you will take no hit with gears at all.
with a .5:1 6th gear I honestly don't think milage would be a factor till 4:56 or lower for most.
I like the way gears make a car drive. most american manufactures leave some preformace on the table trying to avoid the gas guzzler tax.
I really like the way a car sounds with headers though.
I think you should jst decide if you like that tame exhaust sleeper aspect roll some gears. If you want that don't mess with me exhaust sound roll headers.
so my final answer is both. IMO they are both great mods and once you do one most likely your waranty is gone. If I do one I will do both no question.
Old Jun 28, 2008 | 11:12 PM
c6silverbullet's Avatar
c6silverbullet
Originally Posted by C2RMartinez
If you had to pick just one, which would it be, and Why???? Which is gonna get you down the track faster???
If you can only do one right now (say because of $). Why not wait a little longer and do them both at the same time. Doing both together will probably save you some labor cost which you can use towards a CAI like Vararam or a tune.
You can't go wrong with either mod. But if I had to choose only one, I will have to say gears.
Last thing, some here will give you their opinions WITHOUT actually having these mods in their own car
Kenny
Old Jun 29, 2008 | 12:38 AM
3 Z06ZR1's Avatar
3 Z06ZR1
My friend you need a ride in my LS2 vette.. I will be more than happy to take you for a ride and view my gas mileage and sheer neck breaking assault feature of my LS2.
Believe me you won't be disappointed.
Old Jun 29, 2008 | 12:57 AM
Joe_G's Avatar
Joe_G
St. Jude Donor '08
I've tracked every gallon of gas in my daily driver car mostly city driving from day 1. Gears lost 1.0 mpg and the cam lost 2.0.
The gears are a much better mod than a cam or headers IMHO and I've done all on several cars. If you've got one mod to do as I thought this thread was about, go gears.
Old Jun 29, 2008 | 01:38 AM
3 Z06ZR1's Avatar
3 Z06ZR1
[QUOTE=A-Pex;1566089161]Gears!!!
Because AintQik and SpinMonster said so.
Seriously, I would do gears, because for me it's all about performance, not numbers. What on earth am I talking about? Well, I'm glad you asked.
HP/TQ vary as you move through the RPMs and peak numbers don't excite me unless they happen where I drive. Meaning that if I raced my car in the 1/4 I'd probably care more about peak HP than if it's a daily driver because in the 1/4 most of my driving is in the peak range (5K to 7K).
Headers are likely to add roughly 20 - 40 HP depending on other modifications. This will translate into better acceleration to some degree. Gears will not necessarily increase RW HP/TQ, but will likely result in MUCH improved acceleration over the headers (even though the numbers don't coroberate).
I think Spin said he thinks that going from stock A6 gears to 3.42, I would likely experience the equivalent of a 80 - 100 HP increase in real world acceleration. Now that's what I'm talking about!!!
Don't get your hopes up so high This is not what happened
when I added headers then gears.
Old Jun 29, 2008 | 06:21 AM
mvcrash's Avatar
mvcrash
Keep it civil or this thread will get closed. It is summer time, I'm sure come folks could use a Vacation.
Old Jun 29, 2008 | 09:23 AM
xstang's Avatar
xstang
From the line, the gears will give you better acceleration until both cars are moving (providing you can hook up). Let's say both cars on a track start from 30-40mph and accelerate until 130-140.... The Header car will be in front every time....
Just compare trap speeds of the geared cars before and after. About the same or a little less...
Now Compare the header cars before and after 3-4mph gain....
It's a no brainer to me, plus you drop 20-25lbs...
Old Jun 29, 2008 | 10:09 AM
QUIKAG's Avatar
QUIKAG
I have headers, but 4.10 gears are my next mod. I had them on my '01 Coupe and they were awesome.
Re: gas mileage, with the steeper gearing rpm is higher, but throttle application to maintain a set speed is lower due to the gear multiplication. I didn't notice any difference in mpg when I added 4.10 gears to my C5. That said, you want to nail the throttle more to experience that torque hit to the back of your head, so maybe mpg can go down.
Old Jun 29, 2008 | 02:04 PM
3 Z06ZR1's Avatar
3 Z06ZR1
plus the Headers give better mpg. both are good mods though!
Old Jun 29, 2008 | 02:08 PM
  #33
3 Z06ZR1's Avatar
3 Z06ZR1
Originally Posted by 06.Z51.MontRed.Vert
For a short way, the car with the headers will soon pull by.
Old Jun 29, 2008 | 03:55 PM
  #34
k0bun's Avatar
k0bun
From: NJ..."the way I saw it, everyone takes a beating sometimes."
Wow how the hell did this thread get so ugly?
I'll tell you my mod process. My first mods were a Vararam, 4.10s, Borlas, and a CoW tune. I honestly didn't want to go nuts with this car I researched it a lot and my personal opinion was that I did not want headers. The times that I saw weren't that impressive to me considering the price and possible noise annoyance seen from headers + catback on a daily driver. For a similar price gears have proven themselves time and again in many applications and their sotp was apparent at all rpms. My car was quick and had no noise or drivabilty issues. It wasn't until I gave in to the mod bug and decided to do a cam, that I chose to put headers on. It wouldn't make sense not to at this point. As you can see from my sig, I now have a fully built H/C/I motor so I am quite far from headers only. My car pulls like crazy and wont be sneaking up on anyone within a 2 block radius. It is a true daily driver, still with no drivability issues or mpg concerns. I have no regrets but every once in a while I miss the subtle civility of the stock(ish) LS2. Looking back if I had to do it all again. Gears would still be my first mod. Practically undetectable and just pure acceleration.
Martinez, it would help if you gave a little more info. What are your ultimate goals for the car? Do you plan on going further with mods down the road? You have received many good opinions but have yet to comment other than your original post. I'm hoping this wasn't a stir-the-pot attempt. Things usually get ugly when 4.10s are mentioned.
Old Jun 29, 2008 | 04:35 PM
  #35
Slwsvt's Avatar
Slwsvt
There is also one thing to add when considerding the gears vs any bolt on mod. From the point of making the car funner and a overall blast to drive. There is no question that the 4.10s will give you the biggest smile. Which I believe is what most of us are after.
Old Jun 29, 2008 | 08:30 PM
  #36
NOODLESgoneWILD's Avatar
NOODLESgoneWILD
WOW...nice debate, and yes if people don't get upset then these MODS wouldn't be worth the price!
I haven't done any MODS yet, but looks like gears will be first for me!
Im offically a gear head
Old Jun 30, 2008 | 11:43 AM
  #37
DOUG @ ECS's Avatar
DOUG @ ECS
Premium Supporting Vendor
From: Providing the most proven supercharger kits for your C5/6/7 609-752-0321
If I was picking one or the other, (and assuming my needs and future upgrades agreed with..) I would go with the gears first. They will give you the biggest bang for the buck over the two.
Here is our present gear special, don't over pay!!
http://www.eastcoastsupercharging.com/Gears.html
To Headers Vs. 4:10 Gears???
Old Jun 30, 2008 | 12:13 PM
  #38
stroked250's Avatar
stroked250
Just found this: does it look accurate?
http://www.brianhouk.com/Corvette/C6Gearing/
Old Jun 30, 2008 | 12:21 PM
  #39
A-Pex's Avatar
A-Pex
GREAT FIND!!!
Old Jun 30, 2008 | 12:43 PM
  #40
c6Johnny85's Avatar
c6Johnny85
i wud go with the gears bro..because thts a real gud base of performance to start with..
