Only 7rwhp/7rwtq gain from Headers/xpipe
Not saying its a bad thing. I am saying thats where you got alot of your power from. Not your headers
Location: Greater Detroit Metro MI, when I'm not travelling.
Both run the car leaner than stock. Otherwise there would be no point in tuning; it would make virtually no extra power.
But, as many other have noted, most of the gains come from the tune.. I think doing headers and not retuning is a waste of money.
No, I do not have a tstat. But, it is my understand that they are essentially not needed if you have your car pro tuned.
Yea, 15-20hp below what I think would be normal for my car and mods... the car does not feel that strong either. I hardly noticed any change after the headers...
So do you think I should switch tuners? Or before I drop the money on that should I be doing something else?
Headers normally put out 25 HP, exaust 10 HP, headers and exaust 25-30 HP. Typically your header addition should add 15-18 more HP. Appears you are about 10 HP short. My 07 m6 dyno'd at 365 with Halltec, Corsa Sports and a tune. Your ported intake/tb should give 10 HP more. Don't know why your 20 + HP short, my guess is the tune. Good luck.
The before part of the dyno was also after the headers; I posted it because it baselined 364hp; supposedly a stock C6 baselines around 340 - 345hp on that dyno, so it had gained around 20hp with the headers and the intake...
Something is not right for sure. When I installed my Kooks last weekend and loaded the Diablo header tune (not max power Im sure) it will now roast the tires all the way through 1st on a roll. Before the headers/tune it would just faintly chip them a few times as rpm increased. I have a fresh set of BFG KDW's. I noticed a huge difference. Did you figure out the noise from the driver side header?
I'm gunna talk with the shop tomorrow and see what they recommend, it is a different shop from the one I previously went to for my retune after the header install...
We'll see how this plays out once I have a supercharger though
Are you planning more mods? If so get them out of the way before you spend money on a re-tune. I would probably want to go to a different tuner but do your homework first: check for leaks, check the plugs, maybe even check compression if you can... Also as someone else said: a dyno chart, or, better still, a datalog would go a long ways towards identifying potential issues...
#33
rolled in to the tuner with Kook's 1 3/4 's and turned 420rwhp with no
tune. Max dyno after other mods 433 rwhp 430 rwtq.
#36
#38
CF Senior Member
#39
1 Post
I made 378rwhp SAE with a Halltech cai, Kooks 1 3/4" long-tubes, x-pipe with cats, Corsa cat-back and tune. The tune was done before the addition of the long-tubes and I didn't have it retuned.
#40
Former Vendor
I do not know who did the work, but Im willing to take a look at it and see if its on par with the cars we see come through here.
We have a LOT of baseline and before/after runs. Doing a comparison for your knowledge isnt a problem.
Let me know if I can help
Louis
Louis
