COW A6 mail order tune removal made EASY!
Thanks man! I tried to make it easy enough where anyone could study the pics jump under thier car and not run into any suprises.
Does it upshift when tap-shifting it any quicker?
If I was local to Chuck in NY, I would drive over, he hooks up the tune and done.
Personally, I have spoken to Chuck and was willing to participate by not only getting his tune with all the updates, but also making a thread for him just for "those" guys who dont have a tuner to go to and this could be the only option for them.
I was lucky enough to get my '08 done at Corvettes at Carlisle, but after I experienced the results, I'd say it would be well worth all the effort for the mail-order tune if that is your only option. But Chuck does travel the country, look if he will be doing tunes somewhere near you.
As for your questions ...
Overall, I would describe it as feeling like a well driven manual.
On easy acceleration, it stays in the lower gears longer and allows the rpm's to build to a more sensible point before a very crisp shift. On hard acceleration, you see the rev's really build and then an upshift to the next gear that is so positive it sets you back in your seat. That amazing difference is worth five times the price of the tune.
But there is more ...
On deceleration, it downshifts as your speed drops to keep you in the right gear and ready to accelerate quickly again. It even provides engine braking.
I won't be using the paddle shifters any more. I couldn't do any better than what his tune has done.
Someday I'll have to ride in a car with this mythical A6 tune because I dont believe it can be much different than what anyone else can do with HPtuners when tuning the transmission. My car tears into 2nd gear and will get sideways...not hard to tune the tranny to feel great during shifts.
I just want to understand the reasoning for removing the TCM, because unless there is something SPECIFIC that can be done to it that you cannot do when tuning the PCM it seems pointless and wasted.
ZO6 Owner
#33
Chuck's tune for your A6 will end up be the BEST money that you have spent on your Corvette. You could spend money adding more horses, but the stock A6 will still make them seem wimpy. His tune alone gets the stock horses to the road with authority.
Hey man, this is all normal stuff that comes with a custom tune. 90 % of the tuners on this board tweak all the parameters you are talking about. Mine was done by two reputable tuners on here and the car catches a mean 2nd and sometimes a mean 3rd.
It seems like the people with stock cars love a trans tune. People are not realizing that this comes with ANY custom tune. As for modding your car, Lets say you have a magical tranny tune and you go with a heads/Cam swap or a small nitrous shot or a converter swap. You have to send your locked trans computer back again. Your shiftpoints will need to be changed when adding power. Maybe not for an air filter or exhaust but for major power changes you will be riding the rev limiter. To each his own. Good luck with it
#34
Well actually, Chuck gave a great deal on tuning my PCM and TCM so I sent him both. I did talk with him about having another local tuner dyno tune it once the set up is complete and he said it wouldnt be a problem so with faith in that I will hope he does not lock my PCM otherwise I will have a problem getting a dyno tune for L92's and a custom cam. That would suck.
#35
I'm really curious to what he is doing with the TCM that can't be done with the PCM then if you're sending in both.
I'm no tuning master, but I know my way around HPtuners and would be curious to know the added benefit, if any, of a TCM tune for the tranny.
#36
I would love to know the same thing. If my car hit 2nd or 3rd any harder I would be in the Guard rail. I have a few tweaks in my tranny tune. I run 11:30's all motor
#37
Right, I just dont understand why he is sending both the PCM and TCM in when that can all be changed via the PCM with HPtuners.
I also dont know about that 81 cells needing correcting for tire height. I thought that if you just corrected for the tire height in the 1 field of HPtuners you should be set because all of the other values will work off of that number of rotations.
81 values probably get changed when the "overall height" is changed in the program. It is automatically figured out when “overall height” is changed. It’s a formula that happens in the background and changes the values. It changes WOT shift, WOT vs. rpm, etc etc.
#39
Former Vendor
St. Jude Donor '07-'08-'09-'10-'12-'13-'14
Hey JAY....It's 3:26AM my time and your A6 TUNE IS DONE!
It's been crazy up here lately...It's amazing what 2 weeks of NO RAIN does to a corvette business!?!?
Anyway...You lucky dog! I just got finished converting your 06 A6 controller to the LATEST 08 A6 OPERATING SYSTEM with my tune....Your 06 A6 will now have the same amazing tune all my 08 A6 customers get. Right now, there are only 4 people in the country with it...and you're one of them.
Your ECM has also just been upgraded to the latest GM operating system which fixes many common problems including the dreaded DBS (dead battery syndrome). It's all tuned up and...YES, I've set it up so that your other tuner will be able to tune and access your engine calibration for future mods.
You now have the most comprehensive A6 tune available. It's far more than shift points and torque management. Ask anyone who has it. I spent over 3 years and used the best features of 3 different tuning packages to create it....
Your engine and trans controllers will be on their way back to you first thing in the morning!
BTW: GREAT JOB ON THE TCM REMOVAL WRITEUP!
Now, let's see if you can get the TCM back in!
Chuck CoW
Chuck CoW
#40
Chuck CoW
Chuck CoW
Busy is GOOD these days.
