vararam intake
Old Oct 24, 2008 | 06:17 PM
biggn's Avatar
biggn
Default vararam intake
how much time to install on ls3
Old Oct 24, 2008 | 06:22 PM
MSC6's Avatar
MSC6
It really depends. It took my about 2 hours but now I could probably do it in 45 minutes. Here is a link to my install.
http://forums.corvetteforum.com/show....php?t=2112887
Old Oct 24, 2008 | 06:26 PM
Mrs. CoW's Avatar
Mrs. CoW
Do you have the pre-cut shroud?
Is it an Auto or Manual?
Anywhere from 1 hr to about 3 hrs depending on your skill .
Just be careful with the sharp cutting objects if you have to cut the shroud.
FireEyes
Old Oct 24, 2008 | 06:32 PM
biggn's Avatar
biggn
Default re
they don't sell shroud for 08 yet
Old Oct 24, 2008 | 06:33 PM
MSC6's Avatar
MSC6
Where are you located ?
Old Oct 24, 2008 | 06:36 PM
biggn's Avatar
biggn
Default re
long island
Old Oct 24, 2008 | 06:43 PM
MSC6's Avatar
MSC6
OK I was going to say if you were close I would help you with the install but L I is a little far. hahahaha
Old Oct 24, 2008 | 06:55 PM
matt_lowry123's Avatar
matt_lowry123
St. Jude Donor '11
I just installed one on my ls3 and it took about 2 hours. Everything is really easy except for cutting the shroud and it was a pain in the you know what!!!! I broke three razor blades on my box cutter. I wish that I would have had some really sharp scissors or something to cut the shroud with.
Old Oct 24, 2008 | 07:01 PM
SUB VETTE's Avatar
SUB VETTE
SUBVETTE
Buy or borrow a Dremel for shroud cutting.
Old Oct 24, 2008 | 07:22 PM
biggn's Avatar
biggn
Default re
what about wiz wheel
Old Oct 24, 2008 | 07:40 PM
s ladd's Avatar
s ladd
TAKE THE SHROUD OFF THE CAR. I swore I could install mine without touching that condensor, and I was almost finished... However with one last minor cut of the shroud, and I now need a new AC condenser. Take that extra time to remove the shroud to cut it outside of the car.
To vararam intake
