What are your LS2 #'s and with what mods?
Just starting a thread to compare some #'s.
LS2's ONLY!
364 CI ONLY!
What are your mods and what are your dyno #'s?
Ill start:
452rwhp 417rwtq
IPS Stage2 Heads
Custom Comp Cam 232/234 .640I .598E 114LSA
Kooks 1 7/8 LT's
Bassani Exhaust
Ported TB
Vararam
LS2's ONLY!
364 CI ONLY!
Ill start:
452rwhp 417rwtq
IPS Stage2 Heads
Kooks 1 7/8 LT's
Bassani Exhaust
Ported TB
Vararam
477.4 Max RWHP
437.3 Max ft. lbs tq
AFR 205 heads
Ported Fast intake
G5x3 Cam
114 Comp 7.4 push rods
Comp R roller lifters
Halltech Stinger CAI
Ported throttle body
Under pulleys
LG long tube headers
GHL exhaust
AFR 205 heads
Ported Fast intake
G5x3 Cam
Under pulleys
GHL exhaust
1 Post
2005 LS2 mn6
450rwhp SAE
407rwtq SAE
Vararam, FAST, HS 1.7 rockers, Comp Cams 230/236 .608/.613 113lsa XFI lobes, Kooks 1 3/4" long-tubes, x-pipe with cats, Corsa cat-back. Numbers from Dynojet, SAE corrected.
450rwhp SAE
407rwtq SAE
450 rwhp/405 rwtq Livernois stage 2 heads, Comp cam 232/232 .595 114LSA, Kooks 1 7/8 LTH w/3" catted x-pipe, Corsa Sport exaust,Haltech Stinger CAI, MGW short throw shifter, LG World Challenge Chrome Wheels with Z 06 rubber and 390 gears.
I just installed my Procharger a few weeks ago and had the car dynoed. 6psi kit with green top injectors and flowmaster cat back exhaust.
476hp
429tq
I just installed a 4.25" pulley which should give me 8psi and I want to get 500hp to the wheels.
I raced the car when it dynoed 359hp to the wheels with a tune,vararam,flowmaster and managed a 12.1 at 116.
476hp
429tq
Location: Greater Detroit Metro MI, when I'm not travelling.
Pissing Contest?!? I'm in! (just kidding!)
I will start by saying that this comparison is somewhat meaningless because even stock cars will post a variation of +- 20HP or more depending on the dyno they are run at, and the variation only gets worse as power levels go up. That said, here is my contribution:
2006 Z-51 M6, Bone stock engine.
N/A:
Kooks 1 3/4" Headers, Jet Hot Coated
Kooks 3x2.5 catted X-Pipe
GHL Exhaust
VaraRam Cold Air Intake
364.1HP/361.6ft-lbs Torque
As Above, but Dyno Tuned by Charlie at RPM Motors:
394.7HP/387.4ft-lbs Torque
FI:
Same Car, Same Engine
Kooks 3x3 catted X-Pipe
C6 Z06 Exhaust
Ported Throttle Body
Ported Intake Manifold
A&A kit with Vortech V2 Si-Trim Supercharger running a 3.8" pulley
597HP/518ft-lbs Torque
N/A:
GHL Exhaust
FI:
C6 Z06 Exhaust
D1 - Procharger 10 psi
Comp Cam Custom Grind 238/246 611 116 LSA
Patriot Gold Springs
Kenne Bell Boost-a-pump
Kooks 1 7/8" LT Headers
Kooks Hi-flo Cats
Corsa Touring Cat-back
Yank 3200 stall
645 rwhp
Kooks Hi-flo Cats
Yank 3200 stall
645 rwhp
Ls2 a6
411 RWHP and 391 TQ
220/228 duration, .564/.571 lift, 114 + 2 Patrick G Speced Cam
TSP Stage 2 243 heads with 64 cc
LS7 Z06 manifolds/Cats/H pipe
Corsa Z06 Sport mufflers
K&N CAI
Tuning by NRP in Vegas
Daily driver with stock converter
K&N CAI
