Not positive but I think it happens if the car goes below 11 volts. A good cheap start would be to make sure the battery terminals are clean and tight. I would also check my car with a volt meter when the car is turned off and again when the car is turned on. If the battery is below 12 volts when the car is turned off you may be able to fully charge with a real charger or may need a new battery thats losing power on its own.
From: Supporting the Corvette Community at Abel Chevrolet in Rio Vista, CA 707-374-6317 Ext.123
St. Jude Donor '08
We have been replacing more alternators on C6's lately then ever before for this reason. Also, check the terminals on the alt connector. I have seen some of them coming apart lately.
This is the kind of thing warranty is good for.
i,ll bet there arent too many dealers close to him
Set code P0621 "Generator L-Terminal Circuit" to "no error reported" using HP Tuners or EFI Live and your problem will be solved. This I know from experience.
I'll call my tuner tonight.. does it affect the car's power or something?
No, it can happen if you put on an underdrive pulley and it's a common problem for those with underdrive pulleys. If you search you'll see what I mean.
My guess is there's an algorithm for rpm and voltage output, and the underdrive pulley causes the car to not put out as many volts for a given rpm so the code sets and you get the annoying message.
I turned mine off a long time ago and haven't had any trouble since.
Yes, I do have UD Pulley it started 3 days ago..
Thanks a lot for the excellent explanation Joe! much appreciated..
This will address the issue with an under-drive pulley, however it masks the purpose. Can you simply change the threshold that trips the fault to compensate for the under-drive pulley? IMHO I think this would be the most elegant solution. Please let us know! Thanks!
You cannot change the algorithm with HP Tuners...and this solution works as the OP and many others have found out! Sometimes Occams Razor is the best route to take.
Zombie, happy to pass along the solution!
I'm not doubting it works, I was just wondering if there was a cal-constant that could be changed (ie. is the threshold calibratable/changeable)? I am ignorant on this stuff when it comes to late model Vettes, so I was looking for options. Any education would be greatly appreciated!
Possibly someone can correct me if I'm wrong, but I also read(here I think) that this can be cause by the use of unsheilded plug wires causing EM interference with the voltage regulator. I get the same message, don't have an UD pulley and have had the alternator replaced with no change, still get the message.
