View Poll Results: What should I do with the black rims:
Keep them all black
29
45.31%
Paint a thin red lip around the edge of the wheel to match the calipers
26
40.63%
Keep the stock polishe wheels
9
14.06%
Voters: 64. You may not vote on this poll
Getting closer (Wheels are back from powdercoating, reflectors blacked out)
#42
Location: Greater Detroit Metro MI, when I'm not travelling.
Update
UPDATE: just weighted my wheels; 53.8lbs each with a Nitto NT555R2 mounted and balanced, TPMS sensors in place and aired up to 35PSI.
I.E. This tire/wheel combo is approximately 7lbs lighter per corner than the factory wheel/tire combo, despite being 2 sizes wider
Pictures will be up tonight. Yay, nothing like a 14lbs reducting in rotating mass!
For comparison purposes:
Factory rear tire/wheel combo: 61lbs
Stock rear wheels with a Michelin run flat: 60lbs
Stock rear wheels with Michelin Pilot Sport PS2s, one of the lightest tires for this size (non run flat): 56lbs <= This is what I am currently running.
I.E. Running a 305 width tire on a widened 18" wheel is lighter than almost ANY tire you can run on a factory 19" wheel, even in stock (285) width.
(Stock Eagle F1 Supercar tires weight 33lbs, a stock Nitto NT555R2 weights 29.5bs)
#44
Pictures!
Not the best pics; the tires and wheel are dirty and I didn't bother to wash them, but to those who wanted to see what the weld beads look like, here it is:
#48
It'll be a little while still; I bought the fronts (Toyo Proxes R888, sized 265-35R18), and they arrive next week, but I don't think I'll have them mounted and in the car for at least another 2 weeks... The weather is still very cold (it snowed about 2 inches this Friday) so there is little point to attempting to run an R-Compound; these tires have been shown to grip worse than a cheap all season at temperatures below 45F...
#49
I just shipped my wheels to weldcraft thursday, they will ship them to Mike when they are done.
I will ship the fronts to Mike monday.
I got 2 305/35zr18 used, they were shaved and used for one track day, If they work ok then I'll buy a set, or get some Dr's.
#50
I did the same thing... I got a full set of R888s, 305/35zr18 Rears, 265/35zr18 Fronts; I will run these Nittos in the back at first, then swap them out for the Toyos; with a good back-to-back comparison I should be able to decide which ones work best.
They are an identical rubber compound though; I expect them to be very similar.
#52
Sam - The wheels look very nice. I voted for the thin red pinstripe. Here's a picture of mine - painted black lips with a painted velocity yellow stripe. I didn't put on the C6 flag decals, bacause it looked too busy on my wheels.
#53
The 245 is too skinny and will lead to oversteer with a 305 in the back.
The 275 fits on a stock C6 front, but will baloon out quite a bit. It is also quite heavy. I think it would be a good choice and its been tried and proven on the forum.
A 265 is also too wide for a stock C6 rim, but I figured if the 275 fits, this will fit with less balooning. It is also lighter and should tramline a little less... That was my choice.
I spoke with a Toyo Rep and learned the following:
- Toyo owns Nitto. The rubber compound of a Toyo Ra-1 is the same as a Toyo R888 (which superceeds it), and is the same as a Nitto NT555R, NT555R2 and NT01. The only difference is the thread pattern and sidewall stiffness.
- It is fine to run an R-Compound tire on the back and a street tire up front for street usage, but on a race track the car will understeer teminally, and that will quickly get much worse as the front tire gets overwhelmed and overheats past its optimal temperature.
- It is fine to run an R-Compound on the back but if you run one up front it will heat up fast and scrub rubber away every time you take a turn; expect circa 7000 miles from an R-Comp being run in the front, even if the car is not being driven agressively.
#54
I got black powdercoated lugnuts, so I think the decals won't stand out too much from the all black look... Your picture convinces me that the stripe is a good call... I've decided to try a Vinyl one...
#57
Did they get scuffed up during the tire mount process? I see some white edges there- unless its reflection from the camera
#58
They use a white goop to get the tire to slide past the wheel and I haven't cleaned that stuff up yet; that's what you're seeing.
