Thanks again Ranger !
Old Apr 11, 2009 | 04:28 PM
z06tx's Avatar
z06tx
St. Jude Donor '09-'10-'11
Default Thanks again Ranger !
WAS sometimes missing 3rd with hard acceleration. Picture says it all. Everyone needs to read and apply the sticky from Ranger post to clean out clutch reservoir.
Thanks //art
Old Apr 11, 2009 | 04:30 PM
MarkRx's Avatar
MarkRx
blacker than starbucks sumatra
Old Apr 12, 2009 | 07:26 AM
Ranger's Avatar
Ranger
Thanks //art
Glad you found the likely root cause, z06tx. Just stick with it. When the clutch fluid looks like that, it takes persistence to get it clean because the area around the seals in the hydraulics is caked with goo that must be scrubbed out progressively. Fresh fluid will do just that.
I was at the drag strip last week with two new ZR1s. To keep the clutch pedal normal we had to swap the fluid out three-times at pass #10 and again at #20. The fluid accumulated clutch dust that fast under launch and high-rpm shifting. But the protocol kept the clutch/tranny combo happy throughout the day.
Ranger
Old Apr 12, 2009 | 09:00 AM
timd38's Avatar
timd38
I better do mine today.....
Old Apr 12, 2009 | 09:32 AM
Ragtop 99's Avatar
Ragtop 99
If you are reading this, you should have Clicked on Ranger's link!!
Old Apr 14, 2009 | 03:20 PM
Jims Z06's Avatar
Jims Z06
Where do I find Ranger's link????
thanks,
Jim
Old Apr 14, 2009 | 03:38 PM
Ragtop 99's Avatar
Ragtop 99
Zr1 Thread is in blue type. Just click on it. Cool article. That's what I was referring to.
If you are looking for the clutch fluid change help click on the "maintain your clutch" link in his sig.
Old Apr 14, 2009 | 04:29 PM
Ranger's Avatar
Ranger
Happy the info is helpful, gents.
Here is the best thread on clutch care.
Take Care of Your Clutch--Preventing or Curing Pedal Issues
Ranger
Old Apr 14, 2009 | 04:30 PM
Tzzird's Avatar
Tzzird
thanks,
Jim
He either meant Ranger's stickied clutch fluid thread at the top of the forum or the link that Ranger posted a few posts up.
Old Apr 14, 2009 | 04:38 PM
GotVett?'s Avatar
GotVett?
I've done 2 complete swaps now w/pumping and as of today, 2 without pumping (just remove fluid from the resorvoir, clean, and fill back up (per need-for-speed). It's a daily check now until it stays clear (whenever that is).
Old Apr 15, 2009 | 12:27 AM
ZO6Gal's Avatar
ZO6Gal
I started out checking mine every day after reading Ranger's thread. I then changed it on Wed. and Sat. I now change it every Sat and it is much clearer than when I started this process. I have chosen to make it a part of my routine on Saturdays after washing and cleaning my car.
Old Apr 15, 2009 | 12:42 PM
CMY SIX's Avatar
CMY SIX
MGW LTD will also help with 2-3 shifts
To Thanks again Ranger !
