Texas Speed C6 Long Tube Headers & X Pipe Results & Pricing!!
#41
CF Senior Member
Thanked 3 Times
in
You can weld 2 cats into the x-pipe for probably 150 bucks total.
#43
CF Senior Member
Thanked 0 Times
in
#44
CF Senior Member
Then if your getting headers and x-pipe. How much more to be able to hook it to the catback.
#45
CF Senior Member
Thanked 3 Times
in
So probably about 175-200 welded on. My bad
Still save yourself about 500 bucks over one of the big 3 setups if you must have cats on your system.
I would also assume it costs nothing to hook it up to the stock catback since it's made for the vehicle.
#47
CF Senior Member
Thanked 0 Times
in
#48
CF Senior Member
Thanked 0 Times
in
#50
CF Senior Member
Thanked 0 Times
in
#51
Premium Supporting Vendor
CORRECTION CORRECTION!
The C6 headers are in fact 1 7/8", it was the C5 that was 1 3/4"
Sorry my brain isn't working well lately!!
#52
CF Senior Member
Damn jason
you are still around.. i doubt you remember me.. i had an ARE heads.cam 2000 TA back in 2000
i think it was even before you started TSP
good to see you still around.
Also, what is involved on mateing the X pipe to a stock NPP catback?
#53
CF Senior Member
Thanked 0 Times
in
#54
CF Senior Member
Thanked 0 Times
in
#56
Thanked 0 Times
in
__________________
COMP - FAST - PACESETTER - CALLIES - COMETIC GASKETS - MONSTER CLUTCHES - MOSER ENGINEERING - KOOKS
ARP - GM BOLTS AND GASKETS - MSD - NGK - POWERBOND - WISECO - ASP - AND MORE!
Largest Stocking Distributor of LS-x Engines / Largest LS-x Comp Cams Distributor in the Country!
#59
Thanked 0 Times
in
We haven't had the opportunity just yet to test fit this system on our Z06 yet. The headers should, in theory, bolt up and fit perfectly except for not having the d-shaped flange for those LS7 heads. We'll have to see about the X-pipe however and whether or not it mates perfectly to the Z06 axle back. We'll definitely post the results of that test as soon as we can find time to get it done here!
__________________
