High tranny temps,,
Old Aug 25, 2009 | 09:29 PM
1bdasvt's Avatar
1bdasvt
St. Jude Donor '06-'09
Default High tranny temps,,
Diving on the Los Angeles freeways this afternoon with outside temps around 101 and stop and go traffic,,,My Vettes tranny temps got "over" 240 degrees!!
I have an A6 w/ 2800 stall,so I hope an aux. tranny cooler will help.{even though My Z51 has a factory cooler}
Any other opinions?
Thanks,George
Old Aug 25, 2009 | 09:50 PM
LS1LT1's Avatar
LS1LT1
As far as I know, all A6s (Z51 or otherwise) have the same (small) factory transmission cooler.
But yes, the addition of an aftermarket auxiliary cooler should help a lot.
Old Aug 25, 2009 | 10:02 PM
c6 batmobile's Avatar
c6 batmobile
You need a tranny cooler dude before you fry that thing. The factory one is too small. I use a BandM after market one and I rarely see 200.
Old Aug 25, 2009 | 10:36 PM
1bdasvt's Avatar
1bdasvt
Thank You!
1bdasvt's Avatar
1bdasvt
And thank You as well!!
I definetly don't want anything to "fry"!
Old Aug 25, 2009 | 10:48 PM
jmudreamvette's Avatar
jmudreamvette
A tranny cooler is in order with a high stall converter
Old Aug 25, 2009 | 11:45 PM
pistolpete817's Avatar
pistolpete817
See my post
Operating Temperatures After Cooler Installs
7/3/2009
for some idea of the improvement you can expect with a cooler
Old Aug 26, 2009 | 12:48 AM
1bdasvt's Avatar
1bdasvt
Originally Posted by pistolpete817
See my post
7/3/2009
Thanks,,,I just did!
Can't wait to get Mine installed!
Old Aug 26, 2009 | 09:27 AM
PCMusicGuy's Avatar
PCMusicGuy
Those temps seem really high. Does the higher stall really make that huge of a difference? With the stock A6 I see 214 with 105 outside in city, stoplight to stoplight driving.
Old Aug 26, 2009 | 10:29 AM
1bdasvt's Avatar
1bdasvt
I guess.
Old Aug 26, 2009 | 11:23 AM
dennis50nj's Avatar
dennis50nj
i have a 3800 rpm converter, the temps in 95 degree weather stop and go traffic flashing the converter never over 200, then the dealers screwed the trans put new trans in and it ran hot very hot in the 240+ range in 10 miles, found out not enough flow, lines clogged, but i added a cooler and it still ran hot, after they switched lines it dropped too 200, i still think that's to hot since it ran that before with the other trans without a cooler
Old Aug 26, 2009 | 11:36 AM
HinsonSuperCars's Avatar
0HinsonSuperCars
Former Vendor
From: Birmingham, AL www.hinsonsupercars.com 205-909-9402
The B&M Supercooler Transmission Cooler will work great for this.
B&M Supercooler Transmission Cooler $74.95
Seth
Old Aug 26, 2009 | 11:57 AM
herbie1057's Avatar
herbie1057
Seth
DO NOT BUY THIS COOLER!!! Get a cooler with NPT fittings. The hoses slide right off the fittings on the cooler above, I speak from experience.
Old Aug 26, 2009 | 02:29 PM
brianhinson's Avatar
0brianhinson
Former Vendor
Guy above is correct. This is the one that should have been posted. http://www.hinsonsupercars.com/p-111...x-1-12-in.aspx We have all the fittings and SS braided line you may need. Give us a call if we can help.
Old Aug 26, 2009 | 09:45 PM
1bdasvt's Avatar
1bdasvt
Thanks Guys for all the advice!!
Old Aug 26, 2009 | 10:24 PM
jpee's Avatar
jpee
Seth
I have used several different type / brand coolers... with stall up to 3800 & I found Stacked Plate to be 10x better than the finned aluminum type.. when i was using a Vigilante 3800 converter in my 96 C4 I was in stop & go driving in 90+ deg weather and my trans never went over 210 BUT with the finned aluminum I would always go over 230 with only a 2800 converter!!
I Swear By "Stacked Plate" type coolers!!
Old Aug 27, 2009 | 12:35 PM
csun213's Avatar
csun213
Can you post up a link where to purchase the Stacked Plate type cooler? I a very new on trans cooler. Thanks
To High tranny temps,,
Old Aug 27, 2009 | 12:43 PM
0brianhinson
Former Vendor
The two links above are stacked plate designed. Give us a call if we can help you.
Old Aug 27, 2009 | 01:46 PM
Dan Wendling's Avatar
Dan Wendling
Default Cooler Mounting
How about some pictures or description of where everyone is mounting coolers!
Old Sep 1, 2009 | 04:08 PM
ALVETTE00's Avatar
ALVETTE00
I have a 2800 stall too and since adding the cooler, my temps are on avg 30deg cooler!
