ENGINE HOT/AIR CONDITIONING OFF in DIC!!!
1 Post
St. Jude Donor '09-'10-'11
Situation normal
Let me clarify this: While the engine was running, a scanned through the gauges menu till "Engine Coolant Temp XXX" appeared. While that was in the DIC, I depressed the reset button on the pod for about 5 seconds. That did not seem to have an effect. Knowing that the problem was not actually an overheating problem, I drove to the gas station to fill-up and shut the engine off. When I restarted the engine, the DIC was clear and the Temp gauge was functioning again. I do not have a OBD II Scanner, so I never had the opportunity to actually determine the code (PXXX). Because of the sequence I used, I'm not sure whether pushing the reset button was the fix, or restarting after the reset was the fix, or that it just began functioning again on its' own. Sorry I can't be more specific, but if you're having this problem, you may want to try what I did and see if it has an effect on your car as well. I was prepared to buy a new ECT Sensor ($30.82 @ the stealership). The sensor plug and the wires on mine seemed to be O.K. though, so maybe it was just a hiccup!!??
I did try a few things yesterday which included checking on the cable and also removing some coolant from the overflow tank. As it turned out, when I had the thermostat changed to a 160 degree unit, they overfilled the overflow tank. Hence I figured bringing it down to the proper level would be a good idea. I drove the Vette over the weekend and the problem did not re-appear but I am still not confident it went away..
I'm sorry I don't remember exactly, when mine occured (two years ago) the code we pulled up was either:
DTC P0126 Insufficient ECT for Stable Operation
DTC P0128 Coolant Thermostat
With the cooler weather more will experience this. Using HP Tuners we disabled the reporting of this code.
YLOFEVR: The code will still be there, but listed as H for history, not C for current. Check it, you'll see.
1 Post
Codes for this problem
How do I pull-up the codes without an OBD II Scanner?
I had this problem when I forgot to plug the maf back in when I was installing my intake and turned the car on. Only way to clear is with a odb scanner and rest all of the codes. Worked for me instantly. I used a cheapy reset tool.
Jiffy lube, autozone, pep boys,
Coolant Temp Code
Your problem is from the coolant temp not getting up high enough quick enough to meet the GM spec. I had the same thing on my car after a 160 stat install and cooler weather temps. My tuner fixed this easily with his software. As well my tuner will be in BelAir MD. this week doing some work at a Corvette Performance shop. If you want to get this programming done just drop me an email or IM and I'll give you the shop info.
7th Gear
OK - so I am bothered by the dreaded P0128 now - dropped in a much bigger Dewitts Radiator and a 160 thermostat ... we track the Vette and it's FI (Vortech) ... and we run water wetter ... This summer we had huge heating issues (boiled, then blew, the power steering fluids, no less)! But the combination of what we did kept the big Vette tracking flawlessly. But with winter, and as a daily drive, it's just not coming up to heat in the time GM expects (of course).
So, question - can this be managed by re-tooling the software? Are you sure? Seems as though you all are ...
If so, what program(s) / table(s) are involved? What advice do I take to my tuner?
After about 5+ years and 63k miles, this code just came up. It has been much cooler here in md as of late. Reading all the posts has my mind at ease. Thanks.
When I was getting this message it was the fan connector had melted. Check the connector, you can reach it from the top passenger side. Its right behind the fan. Mine had one side completely melted (the red one) and the black one was partially melted. I hard wired the connections and the messages went away.
