**** EnglandGreen New Years Specials! ****
Cruise-In 7-8-9-10 Veteran
St. Jude Donor '06-'07-'08-'09-'10-'11-'12
First and foremost, Happy New Year to all of you! To break in the new year we have decided to throw up some specials for the month of January that were very popular during 2009. I know several people who are scheduled to come in next week will be happy with some of these as it will of course be offered to you.
All prices below include everything you will need with the exception of tax and fluids.
Special #1 - $500.00 off of our custom EnglandGreen Cam kit installs. This brings the cost down to $2495.00 installed and tuned. Before and after dyno pulls will be done as well as our famous Street Tuning. As always, we price things as a complete package with any of our projects so there are not gotchas in there, or “oh by the way, you really need this.” You may take a look at this thread to see what is included with your install. Dyno tuning is of course done on our new 2009 model load bearing dyno.
Special #2 – Header installation. Our normal price on header installation is $2295.00 installed. During this special we will offer you a free dyno tune with the installation. You have your choice of headers from American Racing, Kooks, or LG Motorsports. All three systems are top notch and we support them all. This price does include high flow cats.
Special #3 – Buy a catback of your choice and the installation is free!
Special #4 - *** Differentials, differentials, differentials! ***
The differential pricing below includes installation as well as shipping back and forth for RPM Transmissions differentials! If you have a 2005 and want to upgrade to a 2006, please add $1050.00. GM in all its wisdom decided to use a sand cast case for its differential in 2005 so these are prone to break. GM quickly went back to the die cast in 2006. A4 and A6 transmission computer tunes will be $150.00 for this special.
Quick and easy option for the C5 - Brand new C5 Z06 3.42 differential installed for $1895.00. We keep your core differential.
RPM Transmissions Stage 2 Differential - $1995.00 installed!
- Media blast case
- New seals
- C6 Z06 left shaft
- C6 Z06 2-piece right shaft
- OEM clutch packs
- HD preload springs
- Performance Metal Micropolished gear of any ratio:
- 2.73, 2.93, 3.15, 3.42, 3.73, 3.90, 4.10
RPM Transmissions Stage 3 Differential - $2795.00 installed!
- Media blast case
- New seals
- 300M left shaft
- 300M 2-piece right shaft
- Upgraded carbon clutch packs
- C6 Z06 pinion support
RPM Transmissions A6 Differential - $2195.00 installed!
- Media blast case
- New seals
- C6 Z06 left shaft
- OEM clutch packs
- 2.56, 2.73, 2.93, 3.15, 3.42
RPM Transmissions C6 Z06 Differential - $3195.00 installed!
- Media blast case
- New seals
- 300M left shaft
- 3.73, 3.90, 4.10
*** Transmissions, transmissions, transmissions! ***
The transmission pricing below includes installation as well as shipping back and forth to RPM! Please add $100.00 (normally $200) if you have long tube headers installed. HD upgrades available if needed! Pricing applies to the C5 and C6.
RPM Transmissions T-56 Level IV Transmission - $2195.00 installed!
- Media blast transmission case
- Solid synchronizer keys
- Steel 3-4 shifter fork
- Hand fit sliders and hubs
- New Compressed Carbon blocking rings
- Assembly to RPM's specifications
RPM Transmissions T-56 Level V Transmission - $2695.00 installed!
- Bronze fork pads
- RPM modified 1-2 shifter fork
- Performance metal micropolish
RPM Transmissions 4L60E Level IV Transmission - $2295.00 installed!
- RPM sleeved input drum
- RPM 3-4 clutch pack
- RPM reinforced sunshell with collar and bearing
- Heavy Duty double caged 29 element sprag
- 4L65E low roller clutch
- Billet 4th gear servo
- Transgo HD-2 shift kit
- Corvette servo
- Wide 2-4 band
- Updated aluminum accumulator piston
- Bushing kit
- New shift solenoids
- New wiring harness
- New GM valve body spacer plate
- Seal & gasket kit
- Filter
- Set clutch and band clearances to RPM's specifications
- Each transmission is dyno tested before shipping
RPM Transmissions 4L60E Level V Transmission - $2695.00 installed!
- Corvette servo
- Wide 2-4 band
- Bushing kit
- GM 5 pinion planetary gearsets - front and rear
- Seal & gasket kit
- Filter
RPM Transmissions 4L60E Level VI Transmission - $3195.00 installed!
- Corvette servo
- Wide 2-4 band
- Bushing kit
- 300M hardened output shaft
- Seal & gasket kit
- Filter
Need a RPM Transmissions modified ZR1 transmission installed in your C6Z? Give us a shout. We have done a few of these and they are smooth as butter.
Stall Converters! - $825.00 while doing the tranny at the same time. If you just need a converter installed without the tranny, the price is $1275.00 installed. Add $100.00 if long tube headers are installed. A4 and A6 transmission computer tunes will be $150.00 for this special.
Again, a big thanks goes out to all of you, Happy New Year, and we’ll see you soon for a dose of Necessary Evil™!
Jason & Stephen
WOW! You guys ARE having a sale!
I have to put in a good word for you on this one. You mention in "Special #1" that "As always, we price things as a complete package with any of our projects so there are not gotchas in there, or “oh by the way, you really need this.” ".
That is the absolute truth! The only surprise that I got was better service than I would have expected.
I have been 100% impressed with my entire Corvette Modding experience with EnglandGreen. I have a car that runs like a scalded dog, sounds like the devil lives beneath the hood, and drives with wonderful street manners. Not to mention that I have put 15000 miles on the build without an issue. I get 27mpg, make well over 400hp, and drive the car on roadtrips all the time! Afterall, this IS my daily driver.
Good luck with your sale! I might have to get in on differential this month!
Supporting Tuner
Only 6 days left!!!
Supporting Tuner
Charlie W - 2005 MN6 Corvette, EnglandGreen Mayhem II cam, longtube headers, high flow cats, CAI, stock heads
437rwhp 409rwtq
437rwhp 409rwtq
Supporting Tuner
Only 2 days left!
