z51 Rear brakes = will they fit a 17x8.5" C5 front?
like the topic says, im shopping wheels for drag radials, will the 17" front waggon wheels fit over the z51 brakes?
Yes this is what I run on mine. the only thing is when having them balanced make sure they dont use real think sticky weights. i had a buddy do mine that owrked at honda and we had to redo them casue the first set of sticky weights where to think. but the wheel fits fine!
i ran these tires on my other car too, 406 rwhp, 4.11 gears and they did GOOD.
vette makes just under400 right now, and they will hook up great too.
i have had LOTS of tires and this is the best hooking tire i have found.
im making 500 on motor and just over 600 on bottle. so im trying to figure out what i can hook on..
I would run a P315/35R17 but might need a wider rim. if you have a old c5 rear wheel do a P345/35R18 (but thats a 28" tire) so its going ot change your gearing a little.
Received 2,046 Likes
the 345 won't fit well on a 18x9.5 rim, I'd recommend the hoosier 275/40r17 on a 9.5 rim, lighter and stickier than the m/t, holds 4k launch from 550rwhp and cuts 1.6x...since you have z51 brakes and can't easily run skinnies, otherwise I'd say the 26x11.5 et street like me and "dsp300c" use...you gonna be running out at Dallas Raceway? curious what your goals are?
Have any of the narrow body coupe guys tried the c5 z0 18x10.5s? how bad do theys stick out?
haha, on the tollway is a little different than the drag...I've seen the c5z rear wheels on a c6 while autox and they do stick out a little, there are pics if you search on here. You could then run a 315/30 DR...for stability at high speeds tho, I'd look at the 315/35r18 toyo tq (they hold 2nd for a friends 600/650 juiced c5) or 305/35r18 nitto rII (spinmonster thread)
Mittens, I was considering a similar option. But haven't done the research, or saved the funds yet. I'm assuming you didn't have any clearance issues with those rims, and that was the smallest rim size you could run. Did you just try the 18" or just the 17"?
