Brake lines
Brake lines
I am changing my brake calipers out for powder coated ones. I have removed the front calipers and have the brake lines ends in plastic baggies. Then they are taped up as high as the hose will allow. I do not have time to mount the new calipers yet today. Will the brake fluid gravity feed out? I do not have a Tech 2 device.
Jeff
Jeff
as long as you don't touch the pedal or start the car, I think you will be just fine, SS brake lines as long as you're there? you know your going to have to bleed the system?
Jeff
Thanks for your response. So far, no leakage. As for the SS lines, this is on a budget. My wife doesn't even know about the calipers but she will as soon as she sees the Vette on jack stands!! I bought the speed bleeders for the bleeding and some Super Blue brake fluid. I'm going to purge as much out as possible. Mike the Powder Coater does awesome work.
Jeff
Jeff
All her sisters are married.
You were right about them not draining. They did leak but never came close to emptying the reservoir. Thanks.
