Where does the ground go in a Z06?
Location: Greater Detroit Metro MI, when I'm not travelling.
I'm relocating my battery into the trunk, and want to follow the factory wire path. Trouble is; I can't seem to find the spot where the C6Z ground goes? Can anyone help me?
I have this photo from a grand Sport that shows where the wires BEGIN, and I have the factory service manual showing me where they go, but the picture on the FSM makes no sense.
FSM illustration of where the ground attaches to, supposedly somewhere in the passenger side of the trunk. I looked at it with the manual inside the trunk, butI still don't see where it should be. Where is the wheel tub? Where is the rear speaker? Where is the front or the back of the trunk there for that matter?:
The drawing you posted is correct. Passenger side below the "B" pillar between the rear cargo deck and the door sill. I saw it when I removed the trim to install my harness bar.
The view of the drawing would be looking at the area behind the passenger seat and rear of the door jamb with the door open - as if you were seeing it from the center console.
Can anyone show me a picture of where that place is? No need to lift any trim, just show me where and I'll look for it. I just spent another half an hour looking and I am starting to think maybe it just doesn't exist on a non Z06? I already figured the positive cable crossover isn't there...
Help please?
That divider is fibreglass.
Help please?
Help please?
Looks like that may have been what adam205348 was trying to say.
OK, you got me wondering, so I pulled my panels up to have a look. They have been off several times before, so it only takes a few minutes. The ground location is further up than what your diagram shows, it is actually just above the top of the rear trunk area/passenger compartment partition:
It is directly above the partition I mentioned. The partition carpeting is about 2" wide running horizontal at that point. You can see the carpet turning down into the rear trunk area just behind the ground bolt if you look closely. My race seat is fixed and that is the best picture I could get. It is likely that they did not put the threads for the ground in steel frame coupes, up until the GS manual trans car they didn't need it.
Don't know if this will help you but I just grounded mines to the chasis. It's been working fine. Let me know if you want a pic and I'll snap one tomorrow if it's not raining. I just drilled a 1/2" hole on the side of the box and ran the ground through. Using a die grinder i then cleaned up a spot on the chasis, put a 3/8" clamp on the wire and bolted it to the side of the chasis.
Good luck.
Good luck.
I think sam is wanting to keep from drilling a hole through the box and just try to run it like the factory did on the Z06.
Sam how and where did you run the Positive cable to get it up to the starter and or fuse box?
I am going to be doing the relocation as well and I rather run it like that than drill holes in the fiberglass bucket in the back. But if non-Z cars do not have the ground location or even metal there to make our own ground then going under the car might be the only option.
My problem is I have a 08 and it has a Onstar or XM or something module in the passenger rear cubby hole that takes up room. I will have to somehow relocate that module to get enough room to fit a battery in there.
Sam, the other option would be to run your Negative all the way up and through the firewall as well and ground it to the block or other factory ground location.
That is not a very good option: 1AWG cable is heavy and there isn't really a good spot for feeding the cable through the firewall...
