Speedo drops to zero momentarily and then "service traction control"
Yes, I've done some searching but haven't found anything on this particular scenario.
Car has about 30K miles.
Twice in one week, the speedo dipped to zero for an instant (say around 30mph) and then a "service traction control" message showed up on the DIC. No change in drivability.
I do have the telescopic steering column but its always in the "pushed in" position for what its worth.
Would seem like I have a wheel/speed sensor going out or something.
Anyone seen these specific symptoms?
And now, I haven't had time to go check the codes yet.
TTT
Anyone else? This has happened several more times since my original post.
GM should have made the codes retrievable through the DIC, but they didn't. Consequently, every C6 owner really should have at least a basic code reader in his toolbox. They're cheap.
I think going to the auto parts store and buying a reader is the next step.
P0503 - Vehicle speed sensor (VSS) intermittent.
Guess I'll start out by checking the connector and harness down at the sensor.
Well.....stike one. That sensor is not accessible without yanking some stuff like maybe the shock and half-shaft. Yuck ....I did enough of that on my C5 (like multiple times and I'm still sick of it).
Mine is still doing it several times per month. If cruise is on the cruise control shuts down (of course).
Anyone else having this issue?
Ttt
Received 2,046 Likes
St. Jude Donor '13
Whether or not you wanted to, you paid for a warranty when you bought the car. There actuallly are some dealers that do good work, I'd ask around and give them a try.
Good luck!
Good luck!
Reset the code, restarted it and now no error even after driving.
I don't use the telescoping feature but I do tilt it up and down everytime I get in and out of the car. I've tried resetting the connector at the VSS. Guess that sensor could be intermittent and or the yaw sensor from what I've read. yuck....
All,
I did some debugging on the code per the manual, i.e. some resistance measurements at the ECM, and luckily it didn't definitively point to something other than the sensor so I figured I'd throw the $30 at a new sensor and see what happens.
I did that on the 7th and haven't had any issues. My speedo bouncing (insert BAD mental image here) is quite rare but my cruise would misbehave ALL the time where it would disengage all by itself. I've been using the heck out of the cruise and no issues yet. Not going to call it a success yet but it looks like I "may" have solved the problem. Oh, and while I was down there I tie wrapped the cabling on the driver's side of the tranny so it couldn't move around as much. There was enough slack for it to move around quite a bit. Wouldn't that be ironic if that was the issue.
Glad you fixed it, must have been driving you bonkers for the last 15 months.
I've had my 2008 base coupe for about 2 months now and my car has done this twice. I'll wind it to the top of third and as soon as I hit fourth the speedometer drops to zero until a few seconds after I let up. The Hud also shows zero.
Can anyone tell me how fast 5500 rpms in fourth gear is? That's the fastest I had a chance to get it to so far.
