A couple of easy questions, ok three questions
1. Can only the lens be replaced on the foglamps or will the whole assembly need to be replaced?
2. The Z51 has how many grease zerks on the rear suspension?
3. Shouldn't the rear grease zerks get serviced at least once between regular service intervals if you use the engine oil life as your service indicator?
Thanks,
Robert
Thanks,
Robert
Premium Supporting Vendor
I can answer the fog lamp question. You have to buy the whole assembly. If you're interested in new, let me know and I'll be happy to help.
__________________
Phone: 484-334-8833
Owner of CULTRAG Performance
Shop Our Factory GM Parts Website
Phone: 484-334-8833
Two, one per side on the lower A arm. I grease mine twice a year, once at the start of the driving season,(April) then again maybe 4 months later. (August)
Chassis Lubricant (GM Part No. U.S. 12377985, in Canada 88901242) or lubricant meeting requirements of NLGI #2, Category LB or GC-LB.
I use Mobil 1 Synthetic Grease for all my chassis lubrication needs..Truck, ATV's & Lawn Mower. I get mine at Autozone..
http://www.mobiloil.com/USA-English/...ic_Grease.aspx
Chassis Lubrication (Rear Toe-Link Outer Ends with ZO6 or Z51 Option)
