How to access the C6 DIC Codes ??
Old Feb 17, 2010 | 02:20 AM
Laurent40's Avatar
Laurent40
4th Gear
Default How to access the C6 DIC Codes ??
Hello. Today, I had the check engine light which turned on when I try to start the engine. No way to start the engine and I don't have any messages other than the engine light switched on.
How to access the DIC codes. I tried to apply the C5 method but it didn't work.
Thanks for your help.
Old Feb 17, 2010 | 06:26 AM
foremaw's Avatar
foremaw
Active Streak: 90 Days
St. Jude Donor '08-'09-'10-'11-'12
You cannot access the codes on a C6 like the C5 did, that feature was discontinued on the C6 (unfortunately). To access them yourself you will need to buy a scanner and plug it into the scan port.
Old Feb 17, 2010 | 07:05 AM
GOLD72's Avatar
GOLD72
Unfortunately.
Old Feb 17, 2010 | 09:19 AM
Laurent40's Avatar
Laurent40
4th Gear
Thanks for your quick answer.
Do you recommend a specific place to buy this scanner please ? (Ecklers?)
Old Feb 17, 2010 | 09:32 AM
MARSC6's Avatar
MARSC6
I have one of these.
http://www.amazon.com/Actron-CP9410-...6417088&sr=1-2
Or places like Autozone will do a free scan.
If Ecklers has a scanner I'm sure the price would be ridiculous.
Old Feb 17, 2010 | 09:35 AM
Wayne O's Avatar
Wayne O
CF Senior Member
If you don't want to buy one chances are your local AutoZone store (or somewhere similar) will check your car for codes. Many auto parts stores do this as a free service.
I have an Equus/Innova 3100 code reader...it's one of their middle of the road models but it does everything I need (for what little I use it).
Old Feb 17, 2010 | 09:36 AM
BEZ06's Avatar
BEZ06
You can get an OBD II scan tool from Walmart or
most auto parts stores.
Just make sure it is a CAN capable tool.
Bob
Old Feb 17, 2010 | 09:46 AM
dgrant3830's Avatar
dgrant3830
Wounded Warrior Escort '11
Some of the cheaper scanners out there will only do PCM/ECU codes and not the other modules. You get what you pay for.
Old Feb 17, 2010 | 10:15 AM
RyanC7's Avatar
RyanC7
yep, odb2 port scanner...
Old Feb 18, 2010 | 01:37 AM
Laurent40's Avatar
Laurent40
4th Gear
Thanks a lot to everybody for your help! I might buy one and will provide feedback on the forum about the root cause of my issue.
Really strange as my car was running perfectly last time I parked it inside my garage. I did not use it for 10 days and now it does not want to start....
Old Feb 18, 2010 | 03:54 AM
Jesselsixer's Avatar
Jesselsixer
I wish you the best of luck!
Old Feb 19, 2010 | 12:53 AM
Laurent40's Avatar
Laurent40
4th Gear
Wonderful !!
That is right that Autozone provides you a scanner for free. I paid $160 that will be refundable when I will return it within 90days. The one they gave me, Acton CP9135, wasn't CAN capable... but it was the only one they had. It did not work at all, I had a message "Link Error" all the time.
Well, I decided to check all the fuses removing all of them one by one.
I wanted to share with you one strange think I noticed: in the engine compartment fuse block all the relays were not pluged completely. So I had to push all of them.
And when I started again my vette it worked normally with no more the check engine light on !!!! My car has 28000 miles 2005, so if some of you might have one day this kind of issue, check all your fuses and relays !
Old Feb 19, 2010 | 10:14 AM
dgrant3830's Avatar
dgrant3830
Cool. I hadn't heard of relays coming lose before, so this is good that you found this.
Old Feb 19, 2010 | 06:07 PM
AFVETTE's Avatar
AFVETTE
But I'd still buy a code reader, I think I paid about $75 for my ODB II CAN enabled reader. I'ved used it at least a dozen times - mostly on other cars but it did come in handy when my new (to me 07) Z06 CEL came on. The two codes were common and there was a TSB to correct the problem.
Tom
Old Oct 3, 2011 | 05:03 AM
deekaybee's Avatar
deekaybee
5th Gear
Not sure where I read it but someone suggested reseating all of the fuses and modules. I sprayed them with a contact cleaner and reseated each and my check engine light was gone when I started the car. Who ever posted that info is my new hero.
Old Oct 3, 2011 | 08:56 AM
j_digi454's Avatar
j_digi454
Tom
I have done the same thing. I have since bought HP Tuners (obvioulsy more for tuning) but I still use the scanner for a quick and dirty check when necessary on all my cars.
Old Oct 3, 2011 | 10:14 AM
Tact's Avatar
Tact
Former Law Dawg Moderator
CF St. Jude Co-Organizer
St. Jude Donor '05 thru '24
http://forums.corvetteforum.com/foru...s-or-more.html
To How to access the C6 DIC Codes ??
