42lb to 58lb Injectors Can I drive to get tuned?
Old 02-24-2010, 09:35 PM
Silverboost
Silverboost's Avatar
Default 42lb to 58lb Injectors Can I drive to get tuned?
I am dropping pulley size on my procharged from the stock pulley to a 4.25. While I am at it I am going to change the injectors from 42lb injectors to 58lb fast injectors. Its about 30 miles from my house to the tuner I use. Can I drive the car that far with the 58lb injectors without the proper tune?
Old 02-24-2010, 09:38 PM
0HorsePowerAddicts
Former Vendor
HorsePowerAddicts's Avatar
It will flood badly. I would definatly not drive it without having the injector flow rate table scaled for the new injectors.
Old 02-24-2010, 09:40 PM
Motorhead-47
Support Corvetteforum!
Motorhead-47's Avatar
Leave your old injectors in and drive it to your tuner staying out of boost. Swap to the larger injectors at the tuner's location.
SpinMonster
SpinMonster's Avatar
Change the injectors when you get there. Its a 20 minute thing.
Old 02-24-2010, 09:49 PM
martysauto
martysauto's Avatar
St. Jude Donor '14
Old 02-24-2010, 10:30 PM
DaytonaFIC6
DaytonaFIC6's Avatar
changing the injectors after you get there is a wise decision. I ran my 2004 cammed GTO on 42's without a tune to my tuners house 20min away. It was a terrible drive and it felt like it was so hard on the car. It definitely makes it really rich.
Old 02-25-2010, 07:43 PM
Silverboost
Thanks for the info. I was trying to avoid swapping the injectors in the parking lot but it sounds like thats what I need to do.
Old 02-25-2010, 11:48 PM
3 Z06ZR1
3 Z06ZR1's Avatar
To 42lb to 58lb Injectors Can I drive to get tuned?
Quick Reply: 42lb to 58lb Injectors Can I drive to get tuned?
