Radiator removal / transmission oil cooler lines?
I've searched on this forum and haven't had any luck.
Can someone please tell me if you have to use the quick disconnect tools (J-41623-B & DT-47730) to remove the transmission oil cooler lines from the radiator, or can you just unscrew the fitting from the radiator and leave the quick disconnect fitting attached to the lines.
I got lucky & purchased the DT-47730 from Ebay but so far haven't had any luck removing the 1/2 lines. I hate to have to buy another specialty tool for the 3/8 inch lines if I don't have too, especially since it's about $75.00 for this tool.
Working on my head & cam swap on my C6. So far it hasn't been too tough, but this radiator is becoming a pain.
Any help will be appreciated.
kent moore has the right tools, but they are expensive........... you can take a pick tool, after removing the outer ring back, and very carefully pry the spring clip out of the radiator fitting. your chev. dealer can get them for you if you lose it. pull the line out. to install, put the spring clip back in correctly, and just push the line back in. slide outer collar back in place to secure it. note: you will have to evacuate the a/c system and disconnect the condenser lines to remove the radiator. be sure and get new seals for the lines when going back. thank an engineer for having to do this, as they designed the lower condenser pipe UNDER the side tank of the radiator......
I just removed my radiator this wknd. Well, actually my buddy did. I was busy swaping the clutch assembly. He used nothing more than a tiny flat head screwdriver. Pulled the pin out and used a wrench on the line to break it lose.
As memtioned before - just slide the black protectors and remove the clips with a small screwdriver. The lines can be then pulled out. You might want to cap the lines and the radiator holes to prevent more ATF from spilling. As for the condensor, just move it up and either let it lay on the intake or use a bungy cord to support it out of the way(protect the edge of the hood) for your cam swap. This is what I did when I changed out my cam. Hope this works for you.
2014GT (03-26-2021)
Thanks for your help.
I've been to them all...Autozone, Napa & Pep Boys, none to them sell this tool. This is a specialty tool made by Kent Moore, and the one for the 3/8 line is $75.00...not including shipping, so your looking @ about a $80.00 unless you can locate one used on Ebay.
I got one at Advanced Auto! and yes I have used it, although a pick will do the job
i don't know who told you that, but my dealer has them in stock......
08Csix (08-06-2021)
I originally thought these where a standard type fitting on my 02 NOPE its the quick fit type, this rad cost me $120 but $100 worth of aggravation, but now I know, and I hope this will help somebody with this project. it did save me a bunch of money ! and I like a challenge every once and awhile.
Received 1,194 Likes
St. Jude Donor '15
Or just pull the clips out with a pick? Takes 5 seconds. Put clips back on and push lines in to reassemble. No need for fancy tools.
Also.. This thread is 5 years old...
there are no clips ! this is a quick fit radiator. It requires a special tool, so if you cant see a clip and you are using a aftermarket radiator, find the special tool first. tool takes 2 seconds
St. Jude Donor '15
Amazon.com: ACDelco 24205103 GM Original Equipment Automatic Transmission Fluid Cooler Line Fitting Retainer: Automotive
You are absolutely wrong. There is a clip that runs the circumference of the connection that can be very easily removed. I've done it probably 100 times now on stock radiator. GM uses them all over the place. There's at least 6 on the transmission hoses. They've used them for decades now
I agree the tool is pretty cool, but if you think that's the only way to remove them then you are wrong.
This is the same style connector. The clip going around the outside of the fitting is not a solid piece. It has one open end and can easily be pulled removed
This also shows the "open" end of the clip just to prove that it isn't one solid piece
[QUOTE=schpenxel;1591343439]You are absolutely wrong. There is a clip that runs the circumference of the connection that can be very easily removed. I've done it probably 100 times now on stock radiator. GM uses them all over the place. There's at least 6 on the transmission hoses. They've used them for decades now
So I'm making this up ? 2002 conv sport has a option, the common clip style radiator OR THE QUICK FIT it's a $350 Op type the one I used and made work, "and that's my cost !" you need to do one more radiator, as you have no clue on how the quick fits work dude !
and I thought I was slick, I've done thousands or radiators.
HEADS UP IF YOU ARE GOING TO CHANGE YOUR RADIATOR, FIRST THING YOU ATTACK IS THE TOP TRANS COOLER LINE, IF YOU SEE A CLIP= KOOL. IF YOU DON'T=TOOL. next the drain plug see pix, requires a 1/4 inch drive ratchet and extension OR a 3/16 allen as it's a one way nut.
I try to post facts, posting misinformation hinders members success, and can cost them money and time, so if you want to chime in, please know what you talking about. you can, try to delete post that are misleading, that would be realy helpfull
The right info 2002 sport quick fit transmission cooling line fittings
schpenxel stated..
you are absolutely wrong There is a clip'' Who..ME never, you on the other hand at least once ! NOW THIS IS hilarious, in you haste to post a link to amazon, you failed to look at the common other thing used just slightly down the page. keep up the good work, u r a BIG HELP.
HERE IS A GREAT DEAL ON THE TOOL NEEDED OR should I say required, OR mandatory.
schpenxel stated..
