Z51 rear-toelink Lube Help Please
CF Lifetime Member
I am trying to add grease to the rear toe links, however do I need a special tool or something? I have the pump but it looks like there needs to be an attachment to get it into the toe-end link. Any one?
get the hand pump that has the hose on it.
it just snaps onto the toelink grease fitting nipple.
i keep the connection straight with one hand to make sure the grease goes in and not ooze out (when connection is not straight).
the nipple is accessible without lifting, just go through the wheel spokes and pop the connection on.
CF Lifetime Member
Thanks, the flex hose I bought did not have the the attachment on it and then one that came with it is too long. I am going to buy a different flex hose and get it done. thanks
