Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: General How-Tos
- C6 Corvette: How to Replace Your Power Window Indexing
Step by step instructions for do-it-yourselfers..
c6 convertible electric Top? reset possible?
#41
top won’t move
I’m at wit’s end myself. 2010 GS. One day when putting the top up it just stopped like the others reported. In 5 minutes I was able to pull the top down. I’m not sure if the cover fully latched although it is very close. I’ve tried everything I’ve read to do to no avail. To summarize:
disconnected the battery and re-indexed the windows numerous times
checked all 4 fuses and they are fine
removed the relays and scuffed the terminals to ensure connection
rotated the relays and tried each time to ensure one wasn’t bad. (Side note: it’s interesting mine only has 3 relays on the fuse panel even though the pic in the manual and on the kick panel show 4. The 4th slot is open)
parking brake is pulled
partition is snapped in place
I tested the partition and brake on/off and the car “knows” their position and when out of position so I’m thinking it all works. Is is there any other switch or plug-in I need to check? I’ve had this car six years and it’s been flawless. Thanks for any additional things to check or words of wisdom.
#43
Thank you!!
Power Window Initialize
After a power reconnect such as battery replacement,
the window index-up feature will not function until
the system is initialized. Once power is restored,
do the following:
1. Close the door.
2. Raise the window by pulling up the switch.
3. Hold the up switch for three seconds after the
window is closed. Release the switch.
4. Hold the up switch again for three seconds
and release.
Good luck.
do the following:
1. Close the door.
and release.
Good luck.
#44
Ok , guess Ill try to keep this string alive, been working on my top for a while. haven't figured it out yet.
the Message on the display is: Top not secure, Handle is locked. I replaced the Micro switch in the header, Still get the message top not secure, unlock the latch hold the top button in the down direction, both windows go down, the tonnaeu cover goes up to vertical and the top goes up to vertical and stops. then nothing. I check the micro switches, they all have continuity when the switch button is press , I kept trying and now the cover will not release, Fuses are good. The top will go up from a full down down position to half way and everything stops again , the top module seems to click about 6 or 8 time at this point, don't know if is trying or failing. Does anybody have ideas?
yes I re-indexed the windows, Partition is latched. could it be a the top module?
#45
The switches work in sequence. If they all work, one may be out of adjustment such that it isn’t triggered when the top gets vertical. Not sure about the lid not releasing though. I tried rotating the modules to rule out a bad one. Easy enough to check.
I could hear my lid pull down motor cycling and popping like it was stuck and assumed it had stripped a gear or something. After replacing it (for no reason I now see) it (the whole top process) still didn’t work. The lid would catch on the edge of the waterfall going up and down. I assumed that was out of adjustment which was also wrong. I finally took it in to the Corvette shop here and he ultimately determined the passenger side lid shock had a broken mount. The shock had fully extended when operating the top and everything got out of whack and the switches were out of adjustment. It also had the lid slightly out of align which made it stick at the waterfall.
I’m not sure if something else caused the initial problem and I broke the shock or what. When I was jacking with it trying to see which of the steps were faulty and the lid wouldn’t release at the right time my “encouragement” may have busted the shock mount. The shock may have been faulty to start with and put things out of align causing the whole problem.
The final call was busted shock mount and switch adjustment. Works fine now.
#47
Reset electric top
the window index-up feature will not function until the system is initialized. Once power is restored,
do the following:
1. Close the door.
and release.
Good luck.
do the following:
1. Close the door.
and release.
Good luck.
I wasted ages checking fuse and relay.
I lost my electric top button usage after battery failure.
#49
Top wont close?
Have an 06 and my convertible top opens and goes into the trunk. When I attempt to close it, it gets half way and then stops, the tonneau cover stays up and the top sticks half way ?
I am able to use the power switch to put it back in the trunk and the tonneau cover closes completely but when I try to close it it continues to stop half way??
#51
See the pic in my earlier post.
If you can move the power top manually, it means the pump isn't holding pressure.
#52
This is an old thread, but THANK YOU! I had the same problem and forgot I disconnected the battery when replacing the park microswitch. Couldn't understand why my top wouldn't do anything. Window indexing never crossed my mind, but all is fixed now.
