EnglandGreen Whiplash cam + A&A Vortech =
Supporting Tuner
BradC6 - This 2007 LS2 Corvette came to us from Florida completely stock and unmolested.
We installed our Whiplash cam kit, A&A Vortech S-Trim supercharger, F.A.S.T. 102mm intake (ported by SpinMonster), AFR 235cc heads, Methanol Injection system and American Racing headers.
Stock : 372rwhp, 375rwtq.
With the EG treatment : 665rwhp, 568rwtq
A gain of 293 horsepower and 193 ft.lb of torque with less than 7 pounds of boost!!!
Approximately 785 horsepower at the crank! And it drives like stock :-)
Supporting Tuner
Location: Out Where the Buses Don't Run, Eglin AFB/ Niceville FL
Received 1,433 Likes
2022 Corvette of the Year Finalist -- Modified
2021 C6 of the Year Winner - Modified
2020 C6 of the Year Finalist - Modified
Nice numbers Brad. Stephen and company hooked you up.
I sent you a PM about the wide booty.
Why don't you guys clean things up a little before you button a motor back up. Sheeeezeee. Unfortunately, I bet there are surgeons less meticulous. Great job guys.....way to get a lot (hp) out of a little (boost). Beautiful job!
Supporting Tuner
Look at the pictures...
Supporting Tuner
Heads : Stock 10.5:1 - 64cc Trickflow heads, unmilled, straight out of the box. Stock LS2 GM MLS head gaskets.
Pulley : Standard 3.8 inch A&A S-Trim pulley, no restrictor plate.
Top end power restricted via timing and rev limiter
Stephen
Trust and loyalty is the reason a guy would ship his car past so many closer places to use a distant shop. It says something about a vendor.
Boost : Yes, 7psi because of our Whiplash cam.
Stephen
Stephen
Supporting Tuner
