Z06 fuel pump in 6.0-liter coupe?
I'm R&Ring the fuel pump in my '06 coupe. However, I seem to have wound up with a new pump for a Z06/XLR-V.
Is the Z06 pump module's primary fuel pressure regulator set to the same pressure as the 6.0-liter's? Is the Z06 pump simply a higher capacity unit that's otherwise compatible?
Put it in, and then when you install the E-Force, you won't have to mess with installing the Z06 pump then.
