Air Dam, Cooling and Aerodynamics
Old 04-08-2012, 10:58 PM
corvette103
corvette103's Avatar
My passenger side lower radiator bracket is half broke which I plan on fixing next week, my questions mainly are this-
I have an 07 z51 coupe - can it be raised, at all?
And I know that I can't remove the wider center air damn piece, but what about the 2 side pieces, can I just remove those all together??
Old 04-10-2012, 10:18 PM
corvette_103
corvette_103's Avatar
nothing from nobody? I cant believe no one else has had this idea?
Old 04-10-2012, 10:23 PM
Rafal
Rafal's Avatar
I trimmed my airdam and installed the fangs. still scrapes. still thinking about lowering the rear.
Old 04-11-2012, 03:07 AM
MisterMidlifeCrisis
MisterMidlifeCrisis's Avatar
Yes, you can raise it. The bolts that are turned to lower the ride height can be turned in the opposite direction to raise the car, and some people have done this without apparently any significant handling problems.
Old 04-11-2012, 10:17 AM
corvette_103
Ok great! Thanks for letting me know about that.
Now I need to look into how to do that!
Thanks !!
Old 06-04-2016, 08:24 PM
grumpstar
grumpstar's Avatar
Default 183 coolant temp is no big deal on the vette
[183 temp isn't a big deal, we run 240 on the track
Old 06-04-2016, 10:47 PM
Suns_PSD
Suns_PSD's Avatar
I track my 08 C6 and I would like to know what will absolutely improve my front down force the most. I've never had any issues with cooling ( partly because I only track during the TX winter) so I'm not really worried about that. I already have a World Challenge Hood and I did remove the lower air dam thinking it was an improvement. Also my car is very low. Is The Z06 bumper opening that much larger that the LS7 can be cooled but the LS3 can not through it's front opening?
Good advice appreciated.
Old 06-05-2016, 11:03 AM
Cherokee Nation
Cherokee Nation's Avatar
Originally Posted by 6Speeder
If you have a standard C6 then you need to keep the bottom opening open, not closed. That's where your radiator gets cooling air. And, you need the air dam to force the air in.
IF you open up the front, like a Z06, THEN you can cut/remove the airdam and close off the bottom feed and improve your aerodynamics.
The air dams do no good in town driving, I removed my torn up ones over 2 years ago on my 08 with no change in coolant temperature.
Quick Reply: Air Dam, Cooling and Aerodynamics
