Calculating tire size adjustments
So I have aftermarket rims on my car and the change in tire and rim size to 20's all around has altered my traction control at higher speeds. I have 305 25ZR 20's on the rear. I don't want them any wider if I don't have to, but I would like them taller to help offset this problem and fill out my fender well. Would increasing to a 315 35R 20 reach my goal or would it not work. Thanks for your suggestions.
So I have aftermarket rims on my car and the change in tire and rim size to 20's all around has altered my traction control at higher speeds. I have 305 25R 20's on the rear. I don't want them any wider if I don't have to, but I would like them taller to help offset this problem and fill out my fender well. Would increasing to a 315 35R 20 reach my goal or would it not work. Thanks for your suggestions.
Received 8,928 Likes
The taller tire has to be on the rear to avoid TC problems. It should be at least a half inch taller than the front tire to avoid issues. You can solve the problem by going with a smaller front tire or a larger rear tire.
Bill
Bill
Your 255/30-20 on the fronts are 26.02" diameter. A 305/30-20 on the rear would be 27.20" diameter and would give you the 4.3% front/rear bias you need.
On my stock Z06 my fronts are 25.58" and the rears are 26.68" with a 4.1% bias..
hmmm I wonder why I'm having problems. It only happens at a speed of roughly 65mph and above. The traction control active light comes on at these speeds and I have to turn off the TC to remove the light and be able to accelerate. I do like my TC and don't like to turn it off unless I have to. What else could cause this problem? Thanks for all your replies!
Oh okay, I misread your first post, I thought you meant that my rear tires were currently at at 27.2" diameter. Your two tires sizes is exactly the information that I'm looking for. Thank you so much JoesC5!
Now you just have to find a tire in the new size that's the same brand/model as your fronts. Good luck. I don't recommend mixing different brands/models.
Here's a site that will help.
http://www.1010tires.com/TireSizeCalculator.asp
Bear in mind that every tire company has their own way of measuring their tires so the calculated diameters won't be exact.
