Carb'ed LS3 + 4L80 info needed
Old Dec 12, 2010 | 07:50 PM
BartonekDragRacing's Avatar
BartonekDragRacing
Default Carb'ed LS3 + 4L80 info needed
I'm looking to build a carb'ed LS2/3 for my '88 vette turbo project.
I know they sell carb'ed intakes that work with LS3 heads and I have the part # for that from Summit..
Keep in mind this will be a single turbo vette so I would like to buy 1 part that will work for both n/a and turbo.
what kind of ignition would I need? MSD-6012? What coil? blaster coil? Is there a MSD ignition box that will work with a LS2/3 engine that has boost/timing retard and handles a crank fired ignition setup?
I'm assuming with a 4L80 I can convert it to a manual valve body along with the usual mods to beef it up and I shouldnt need any computer or harness for it..correct?
