C6 Clutch Replacement
Old Jan 8, 2011 | 01:00 PM
74c395c4's Avatar
74c395c4
Default C6 Clutch Replacement
Any tips on the best way to replace my clutch for a 2005 C6. I have the factory service manual and it seems extremely complex. Dropping the rear suspension and then the transaxle etc. Is this easier than it sounds?
Old Jan 8, 2011 | 01:19 PM
carlrx7's Avatar
carlrx7
St. Jude Donor '08-'09
that or pull the motor
Old Jan 8, 2011 | 02:32 PM
hebdog7's Avatar
hebdog7
Easiest way.....take it to a shop. It will be a PITA with out a lift.
Old Jan 8, 2011 | 02:50 PM
eboggs_jkvl's Avatar
eboggs_jkvl
Moderator emeritus
2015 C7 of the Year Finalist
Elmer
Old Jan 8, 2011 | 02:52 PM
timd38's Avatar
timd38
In your 20's, everything looks easy
In your 30's, most jobs are not bad to do
In your 40's, you wonder why you do it
In your 50's, you ask how much it costs
Old Jan 8, 2011 | 03:08 PM
05C6GAC's Avatar
05C6GAC
Old Jan 8, 2011 | 03:19 PM
joghotrod's Avatar
joghotrod
If you have a lift and a heavy duty trans jack, it is not that hard. I rebuilt my 6mn in my C5 when I was 62. It also helps if you have a 30 year old son that shows up just in time to help get everything on the ground once you have it all unbolted. He also was there when I got ready to lift it back into the car. I didn't change the clutch at the time, but it would have been easy to get to with everything else out of the way. I found that if you take your time and have the right tools the Vette is very easy to work on.
Jimmy
It also helps to check the forum for how to writeups with pictures. They helped me a lot.
I saved over $1500 by doing this myself.
Old Jan 8, 2011 | 09:36 PM
74c395c4's Avatar
74c395c4
I'm 58 with a 26 year old son so I think I'll try it.
thanks for the encouragement.
Old Jan 8, 2011 | 09:45 PM
hebdog7's Avatar
hebdog7
Let us know how it works out.
Old Jan 9, 2011 | 06:43 PM
joghotrod's Avatar
joghotrod
You are very welcome, Good luck and take your time.
Jimmy
To C6 Clutch Replacement
