TPMS sensors
Old Mar 3, 2011 | 01:30 PM
SUB VETTE's Avatar
SUB VETTE
SUBVETTE
Default TPMS sensors
Do TPMS individual tire sensors have batteries that need changing? I noticed a tire company advertising an fee to rebuild the sensors during a tire change. What needs to be rebuilt?
Old Mar 3, 2011 | 02:33 PM
BEZ06's Avatar
BEZ06
The term "rebuild" is kind of a misnomer!!!
Normally when tire pressure sensors are removed and remounted, the shop will often do a "rebuild" and charge about $6 or $7.
The "rebuild" simply consists of a new rubber grommet, a valve stem core, a retaining nut, and a valve stem cap, like you see below:
So.....it's not really "rebuilding" the guts of the sensor at all.
There's really no way to do anything to the internals of the sensor - at least it's not designed to have any work done on the inside.
There are a couple guys in the C5 section that replace the batteries in C5 sensors, but I'm not sure what the rate of good success is with the procedure. Below is a link to a 4-part video if you want to see how they do it:
http://www.youtube.com/watch?v=QjrT7WBG6U8
Bob
Old Mar 3, 2011 | 03:05 PM
SUB VETTE's Avatar
SUB VETTE
SUBVETTE
Thanks for the info Bob.
Old Apr 12, 2011 | 10:41 PM
KENS80V's Avatar
KENS80V
Is there a single GM part number for the kit?
To TPMS sensors
