Pull codes
Old Apr 23, 2011 | 06:04 PM
lucifer8's Avatar
lucifer8
Default Pull codes
Hi.
What´s the best way to pull the codes in my Z06 2006, i´m having some problems with the ABS.
What should i buy?
Old Apr 23, 2011 | 07:06 PM
BEZ06's Avatar
BEZ06
You need a CAN capable code scanner to hook up to your OBD II port.
The problem is, most of those tools can't read much in the way of ABS codes - you may need a Tech 2 to get the ABS codes you need to make a good diagnosis.
What kind of problems are you having with your ABS - Just some DIC messages, or are the brakes doing something weird?
Bob
Old Apr 24, 2011 | 02:33 AM
lucifer8's Avatar
lucifer8
Hi.
The ABS and tracktioncontrol stop working when i drive about 1 mile or hit the gas fast.
Also hve some truble with the engine light, sometimes when i start the engine the check engine lamp goes on and the rev counter doesn´t move and the engine runs bad?
To Pull codes
