Starter repair in Phoenix
Got in my daily driven 2006 A6 on Wed morning to go to work and nothing but a click. I went to Checkers to get a battery and they said my 2 year old Delco was fine. Went back and tightened the nut on the starter solenoid. No luck. Batteries don't last much longer than 2 years in Phoenix, so I went to the dealer and bought a new one for $130. The group 90 at Checkers was $100 and they didn't have one. Since all you do is rent a battery, I figured I better get the one at a Chevy dealer so I can get one in any town I might be in during a trip.
Well, Checkers was right, still didn't fix it. So I dropped the starter. Took me a little longer because I had to loosen the header on the passenger's side. It also hung up coming out, and I forgot about the shim you have to loosen. Man, it's been 20 years since I took out a starter. I just loosened the small bolt that holds the plastic shim in place and the starter came right out.
Looking at my options, everything took time. Checkers or Autozone had to order the starter and wait a couple of days. Chevy wanted over $400, Gene only wanted $300, but shipping would take 5 days. I then remembered a small electrical shop that I used a long time ago to rebuild 911 alternators: C&C Electric at 3046 E. Southern in Phoenix.
So I called C&C and they said they could fix it. Drove over and talked to the son, who is my age, 57. His Dad used to work at Garrett, where I have worked for over 33 years. I said, "I assume your Dad has passed away." He then hollared at a guy with a welder's helmet on. This old guy lifted his helmet and the kid said, "Hey Pop, this guy thinks you are dead!" We all got a good laugh. This old guy had gone to work for Garrett in 1953. I went to work for them in 1976. My employee number is 13XXX. His was 42.
Anyway, he rebuilt the starter for $100 and it looks great. He said the armature was "open." He put in a new armature, greased the planet gears, put in new brushes, and it was done the next morning.
Putting it back in took about an hour in a half. It was a little awkward because I didn't have the car high enough on jack stands. Got everything buttoned back up and viola, fired right up. What a great feeling. I had also bought a starter thermal blanket, but decided to put it on the headers next to the starter. That might have been a mistake because I'm not sure it will take the heat. If it melts, I'll take it off and get some header wrap.
If anyone in Phoenix wants to avoid a $400 starter, take yours to C&C. I like keeping my original starter because I know it only has 42,000 miles on it. You have no idea what you will get from Checkers or Autozone with their rebuilds.
Nice story. I too found that our starters are hard to find. I had to mail order it from DB Electric. ~$75 shipped, no core charge. http://www.db-starter-alternator.com...-60-liter.aspx
The reason I had to replace mine is the plastic housing on the solenoid that holds in the lug that the battery and alternator attach to cracked from heat fatigue, likely due to the headers. Did they replace the solenoid housing on yours?
Received 2,481 Likes
St. Jude Donor '15
"In honor of jpee"
really good story. finding a shop that rebuilds electrics is not easy today. I'm sure they're out there, but nearly as many as there used to be.
Thanks for the comments. 5 Liter, how is that $75 new starter? Obviously made in China, but I'm betting the OEM is also made in China. Looked nice in the photos. Probably worth buying one just to have around as a spare!!!!
Les, my car has 42,000 miles on it, way too soon to have a starter go out. I hate to say it, but typical GM, starters, water pumps, and alternators do not last long enough for me.
Its in and goes vroom so I'm happy.
It did have a "made in China" sticker on it but I don't really care.
I think I'll order one for a back-up. Since this is my daily driver, I can do a starter swap in a couple of hours and not lose a day of work.
Thanks,
Received 2,061 Likes
5 Liter, thanks for the recomendation. At that price, I decided to go ahead and get one. Heck, I hope I don't need it for 5 years (that's how long my OEM lasted), but I figured if I don't use it before getting rid of the car (which I may never do!) I can always sell it.
Thanks,
Thanks,
So true! This is the first car I've had that was an auto. Whenever I've had starter problems before I could always bump start it.
My OEM lasted 72K until I broke the bakelite solenoid battery stud. I got a $90 O'Reilley's replacement. As I sourced it, I found they were manufactured in Michigan and may be the supplier for GM, etc.
I'm on the third alternator. Number one died at 800 miles and the second at 51K.
Strange as it may seem, the OEM water pump is still going strong at 104K.
Now that I know you have a spare, you're going to be my emergency supplier.
