c6 intake
Old May 13, 2011 | 03:52 PM
enokcud's Avatar
enokcud
Default c6 intake
can someone tell me whats so good about changing to a c6 intake on ls1 what are power gains an so on?
Old May 14, 2011 | 05:44 PM
smurfkiller's Avatar
smurfkiller
do you mean the intake manifold? or the filter and intake tube?
the intake manifold from the c6 you can use is the only the LS2 and it sucks unless it has been ported, you want a LS6 intake manifold. if you mean the filter and tube just buy a aftermarket set up.
Old May 14, 2011 | 05:47 PM
FloydSummerOf68's Avatar
FloydSummerOf68
I've never heard anyone say that an LS2 swap on an LS1 was something people consider. The LS2 setup sucks.
Old May 14, 2011 | 06:34 PM
LS1LT1's Avatar
LS1LT1
It's been done on cars with LS1 intake manifolds and it helped a little bit (probably due more to the larger 90mm throttle body opening than anything else) but one would likely be going backwards if they replaced an LS6 intake manifold (be it on an LS1 or LS6 motor) with an LS2 manifold.
Old May 14, 2011 | 08:24 PM
smurfkiller
well wait a min wasnt it in 2002 when gm put ls6 intakes on all the motors ls1 and ls6. i would say you would see considerable gains in switching to a fully ported(center post removed) LS2 intake due to 90mm throttle body opening. and if you really wanna pick up go to 90mm TB as well.
Old May 14, 2011 | 10:46 PM
LS1LT1's Avatar
LS1LT1
Yes, but it was model year 2001 actually.
It would seem that way and yes switching to a 90mm throttle body opening (and throttle body) should let more air in but still many tests have shown that the LS2 intake just does not flow as well as the LS6 intake does.
Old May 15, 2011 | 03:26 AM
SpinMonster's Avatar
SpinMonster
Yes, 2002 for F-body Ls1's and the 2001 corvette got the Ls6 intake manifold and block in the second 1/2 of the run. My 2001 had the LS6 block.
If the TB is a restriction, then yes. the real bottle neck is the MAF in front of it but it takes big power to have that be a restriction. A 440 motor I helped with saw a big gain with a Lingenfelter MAF. The motor was in a C5. It was in the 540rwhp range.
I dount it will be a big help on H/C motors.
I was wrong in the past about the MAF screen so if you do swap out for a 100MM maf, use one.
I think the TB after the MAF is the next bottle neck. FI would definitely benefit.
The LS2 intake manifold has the worst looking runners and the LS3 has the best looking being there are no casting marks (LS3 and L76). The LS6 is much like the LS2 in regard to casting marks where the sections of the plastic come together. While both respond to porting, a really bad LS2 will pick up the most power. An LS3 picks up the least amount.
Old May 15, 2011 | 03:58 AM
LS1LT1's Avatar
LS1LT1
Actually it was 2001 for the F-body LS1s as well.
Old May 15, 2011 | 03:21 PM
FloydSummerOf68
Well my point was that I wouldn't see why they wouldn't just swap to the readily available LS6 intake which is far superior.
Swapping to the LS2 intake is just swapping out junk for junk.
To c6 intake
