Question about the MAF Position
Old Aug 2, 2011 | 11:36 AM
GotVett?'s Avatar
GotVett?
Default Question about the MAF Position
Although it doesn't seem that it would make any kind of difference at all, would rotating the MAF slightly either way make any kind of performance difference? Possibly gas mileage, etc.? Seems that I read it somewhere here on one of the posts.
Old Aug 2, 2011 | 01:40 PM
GotVett?'s Avatar
GotVett?
Tough question . . . must have stumped the panel.
Old Aug 2, 2011 | 02:17 PM
LEAVINU's Avatar
LEAVINU
Sounds like a hoax to me. Not really sure how keeping it at the same part of the intake tract but turning it a few degrees would alter how it reads in any manner.
Old Aug 2, 2011 | 02:26 PM
GotVett?'s Avatar
GotVett?
My gas mileage had been off from my usual (with the same driving habits) and this was why I was inquiring. I've since cleaned the MAF and things have gotton better. But I did read on one of the threads here weeks ago about rotating the MAF to improve the flow, etc. I've taken mine off a number of times while working on things and there's nothing there that would dictate a degree change by rotating it a little. Again, wanting to see if this was an area more knew about but obviously not nor should it be. Thanks for the input nonetheless.
Old Aug 2, 2011 | 02:47 PM
smurfkiller's Avatar
smurfkiller
nope shouldnt make any difference at all. now if you turn it around backwards you'll see a change.
Old Aug 2, 2011 | 04:44 PM
GotVett?'s Avatar
GotVett?
Won't be making a thread about that . . .
Old Aug 2, 2011 | 05:58 PM
youout's Avatar
youout
Originally Posted by GotVett?
: I've since cleaned the MAF and things have gotton better.
What is the best way to clean the MAF?
Old Aug 2, 2011 | 06:06 PM
crusher1's Avatar
crusher1
I use CRC....every spring I will give it a good cleaning...Works great
http://www.crcindustries.com/auto/co....aspx?PN=05110
Old Aug 2, 2011 | 06:09 PM
GotVett?'s Avatar
GotVett?
Right. CRC Mass Air Flow Sensor Cleaner is the best. Just don't touch the wires inside it. Not hard at all.
Old Aug 3, 2011 | 08:17 AM
REVAK's Avatar
REVAK
In "theory" it should improve air flow if rotated 90* to be inline with the throttle blade. I did rotate mine to that position, no problems , but it is hard to determine the benefit, if any. This is similar to indexing spark plugs , some do it , for whatever slight gain may be obtained.
Old Aug 3, 2011 | 09:12 AM
GotVett?'s Avatar
GotVett?
That may have been what I read somewhere here. If I were to do it, I probably wouldn't notice any difference.
To Question about the MAF Position
