05 vette will not start, help plz!
Old Aug 3, 2011 | 06:03 PM
eastman9899's Avatar
eastman9899
8th Gear
Default 05 vette will not start, help plz!
couldnt find a related thread but if someone could link it if it exists that would be great.
been driving the vette all week, but this morning she wouldnt start, the battery seems good, i did try and jumper the battery with my truck with the same results
all the accessories/radio and the a/c come on but the engine will not turn over. what am i not looking at?
Old Aug 3, 2011 | 06:40 PM
saplumr's Avatar
saplumr
Bad battery or clutch switch not closing.
Old Aug 3, 2011 | 06:43 PM
DSOMC6's Avatar
DSOMC6
First thing: take your battery to somewhere that can load test it. You can still have radio etc working at min charge. Failure to jump start doesn't mean battery isn't bad. It's summer...running a/c radio etc kills the remaining life of a battery pretty easy. I managed about 2yrs avg with ac delco before I switched manufacturers.
Edit: It's a 2005 model year! Search under the term DBS!!!
Old Aug 4, 2011 | 06:31 AM
my2005c6's Avatar
my2005c6
Mine did this before and ended up bringing it to the dealer for the ecu reflash update for 2005. Before the reflash I replaced the battery and every once in a while it would do what yours is doing even with the new battery. Try this, disconnect your battery for a couple of seconds, reconnect and start her up.
Hope this helps.
Old Aug 4, 2011 | 07:53 AM
Vette_DD's Avatar
Vette_DD
Just remember that after a battery disconnect/reconnect, you'll have to reset the window indexing and probably the clock.
Here's how to reset the window indexing:
Close the car door. Raise the window and hold the up switch an extra 3 seconds. Release. Without lowering the window, hold the up switch again for 3 seconds. Release. Done. Don't forget the other window.
Old Aug 4, 2011 | 07:11 PM
eastman9899
8th Gear
thanx for all the info guys.
good stuff to know.
battery was dead, running like a champ again.
To 05 vette will not start, help plz!
