C6 Radio Problem
Old 08-20-2011, 05:07 PM
Dakota67
Cruising
Dakota67's Avatar
Default C6 Radio Problem
I saw an old message about this probelm but did not see a "final answer."
My radio started powering up only intermiitently. Sometimes I start the car, turn on the radio and nothing happens. If I stop the car and start it again, often the radio will work.
From what I read it appears to be a software problem and my Chevy dealer says the only fix is to replace the radio.
Is this true?
I haven't got the estimate to do that yet.
Are there better replacement radios other than GM that would be less expensive?
Is the radio easy to pull out? Pull the ***** - pry off the cover plate/bezel - take out a few screws and remove? I couldn't find a "how-to" thread.
Old 08-20-2011, 05:24 PM
Vette_DD
Support Corvetteforum!
Vette_DD's Avatar
Received 1,276 Likes on 935 Posts
Happened to me on one of my earlier C6s. Local dealer tried a software fix, but when it continued to happen, they had to replace the radio. Fortunately, mine was still under warranty, so it didn't cost me anything.
Old 08-20-2011, 05:30 PM
RicK T
RicK T's Avatar
You didn't say what you have so this may or may not relate to your car:
http://forums.corvetteforum.com/1574503413-post3.html
Here's what you have to do to do a radio swap, part 1 and part 2:
http://forums.corvetteforum.com/1556775685-post1.html
http://forums.corvetteforum.com/1556776360-post2.html
Old 08-24-2011, 10:30 AM
Dakota67
Cruising
Dakota67's Avatar
Rick,
Thanks for the radio removal links.
I don't have Nav, so I assume that the dealer solution of replacing the radio is this only fix.
Old 08-24-2011, 10:35 AM
RicK T
RicK T's Avatar
Probably.
Might want to take the time to look for a used one. Lots of guys are taking out their factory units, Nav and non-Nav, and replacing them with aftermarket. Would certainly be a lot cheaper than buying new. Good luck.
Old 08-24-2011, 10:38 AM
Z11409
Z11409's Avatar
On my 3rd. radio,GM said it was because of mositure in the switch.
To C6 Radio Problem
Quick Reply: C6 Radio Problem
