ZR1 cam in LS2
The cam bolts are 8mm thread and the correct torque if you are using foot pounds is 27 to 28. 18 ftlbs is for the timing cover, oil pan, rear cover etc. And do clean out the threads with contact cleaner so they are oil free, otherwise not a loctite in the world will cure and stick properly. I have done so many cam jobs in these engines I can't begin to say how many, and not one bolt related failure.
I had it happen to me also
I had the timing gear come off on my stock engine at 25K and did tons of damage. Needless to say on the rebuild I used ARP bolts and Loctite on EVERYTHING !!!
7th Gear
What's up with the cam bolts comming out? My 05 just turned 50000 miles on it and my LS2 was destroyed. Chevorlet claims that there is no prolblem. Hard to belive when it's going to cost 10 grand to fix!
C6SNAKESKINNER
C6SNAKESKINNER
that's sucks big time, I was hoping it was only me, I went with a brand new long block from Texas speed and they installed their cam and everything.
