Failure with WCC lowering bolts
I purchased these bolts about 3 months ago, and installed them exactly as directed, lubed them an everything. Started to noticed a creeking from the rear. I lifted the car up and found the rear bushing of the lowering bolts barely hanging on. I picked up a front and rear set of the zip lowering bolts asap after I found out that I wouldn't be refunded (awesome customer service). Anyway. I removed the front and rear lowering bolts, and replace them with zip bolts and cushions - fantastic customer service btw A+. Here's a couple photos of the front and rear bolts. Rear bolts show total failure, and the fronts are starting to rub through already.
I expect that the Zip units won't last a hell of a lot longer. The abuse that those little things take, combined with design+material that's clearly not up to the job, means failure is inevitable (and sooner rather than later.)
Been there, done that with my wife's C6. We started with WCC bolts. The rears lasted four days. Changed to Eibach. They lasted about 6 months. We finally bit the bullet and went with Pfadt coilovers. Yeah, it's a lot more money but the problem goes away completely and the car can be lowered/raised/adjusted as you like.
Just think of each corner's little rubber bit being hammered by 800+ pounds of car every time you hit a bump. Think those things are going to last under that assault? Heck, I'm impressed that they last as long as they do.
Z//
Z//
I couldnt agree more. I'm one of the many that bought into the idea that some have had these things installed for 6 years now with no issues... I dunno.
Using the forum to gauge reality is a seriously iffy business.
Z//
Received 2,481 Likes
St. Jude Donor '15
"In honor of jpee"
this isn't the first time we've seen this, and probably not the last. XO makes some good points.
St. Jude Donor '15
"In honor of jpee"
what he said....^
I was trying to be too roundabout and got lost in the traffic circle..
The only bolts that stand a chance in that environment are the Hardbar bolts. But they have zero cushioning on them so, while they last longer, they also ride like a freight car.
If you can't go low enough with the stock bolts to make you happy you're either going to go into "bolt hell", cut the stock ones down (knowing that replacing them will cost you a full set of springs since you can't buy the bolts seperately - approx $300 each at today's prices) or go with coil overs ($$$.)
Nothing's simple any more.
Z//
Z//
Z//
Z//
Z//
Well, WCC isn't the manufacturer but you do have to wonder why a Corvette parts seller - one with a supposed good reputation - would continue selling something they *have* to know by now is junk and costs their customers a ton of aggravation and disappointment while sullying their own reputation. An odd business model, IMO. Caveat Emptor, indeed.
Z//
Z//
****. I'd at least install them if they lasted. A slightly harsher ride is almost a sad tradeoff for a lowering bolt that will last more than a few months.
The Hardbar parts are really meant (a) for race cars and (b) to be replaced fairly regularly. To criticize them based upon their use in street cars is unfair. They're not meant for that and it shows. False expectations and all that.
Z//
Z//
Incorrect. Gary himself said they were a great choice for the street and would outlast the competition due to the Delrin material.
