2008 A6 replaced due to stall converter?
I installed a 3600rpm Yank converter in my 2008 Vette. After a year or so noticed the trans flaring and hunting for the correct gear. GM tried to repair the trans multiple times but could not, resulting in a replacement trans. The service manager claims the converter caused the problem and refused to put the Yank converter back in the car. Since this was a warranty I went with the stock converter. I did not race the car but also don't baby it. The tech told me that there were burnt clutches but said that seals were put in wrong at manufacture and caused the problem. Not my converter. Car works fine now but I do prefer the Yank stall. As stated I didn't race the car and did not add an additional trans cooler. Does anyone have a similar experience or opinion on this. I'm deciding on whether the Yank goes back in or not. Thanks in advance.
i would send the converter back to get cut opened and checked for debris in it, see if clutches burnt, once you get it back put it back in, the dealer did the same thing to me on an 05 a4 trans, i put the converter back in and its been fine for 4 years
Received 2,061 Likes
In my experience, the racing part creates less heat than heavy city traffic or uphill grades. The longterm heat is a bigger threat to longevity than a few quick passes at the track.
But a larger/more efficient radiator might also absorb or hold more heat in (better in there than in the motor of course) if it's doing it's job well and that would also mean that the factory transmission cooler that runs through it will also run potentially hotter.
But please don't quote me on that LOL.
I think the aftermarket/auxiliary trans cooler is still the best way to go, whether it's run in conjunction with the stock/factory one that still runs through the radiator or bypasses the radiator entirely and acts as the sole trans cooler.
I have one in my car, it's been flawless.
I do run my car and live in Fl so temps are a problem, I installed a Cooler and temps are no issue.
good Luck!
