Routing Oil Lines to DeWitts Radiator
I have a 2006 that I am installing a DeWitts radiator with internal oil cooler. I have the adapter for using AN fittings and braided lines. Can anyone give me any information on how you routed the oil lines from the adapter to the radiator.
Thanks Gary
Thanks Gary
if you have the lines and fittings already then they run through the motor mount along the block. if not the best is to get the hard lines from Tom at Dewitts. better flow and fit correctly
they slip right in after you loosen the motor mount and lift the engine a bit with a wood block & and a jack
Are you sure that this is it?
http://www.partstaxi.com/parts/2005/...iagram=CF05050
I have an 07 and a Dewitts to install wiht the EOC. I was planning on getting the Kaltech oil block and then asking about what braded lines I need to custom build. I can see that a 90 degree and a 45 degree are used from the block but don't know how long the lines need to be or what type of end fitting is needed at the radiator.
This GM part is cheap and if it does it all, and you are saying you get better flow then that would be great. Are you positive I don't need anyting else but this part?
Track Junky
I have 05 Z51 oil cooler lines available if you need them. Perfect shape with 38k miles on them - i swapped to an external Z06 cooler and dont need them. Shoot me a PM with what you think is a fair price and cover shipping and they are yours. Should save you money if that's the direction you want to head in.
