07 C6, what model? 3LT? I think, need some help
Im looking at buying a 07 C6 coupe. All though I can find no info on which model it is.
It has navagation, HUD, auto-dim mirror w/ on star, heated seats, steering wheel mounted radio controls, power telescoping steering wheel, 7 speaker audio, cross-drilled rotors, and 6-way power drivers seat (didnt look at the passenger side). Ive found an optons and equpiment list from 07 here,
http://www.c6registry.com/Facts/2007_guide.pdf
and it looks to be a 3LT. Can anyone confirm this for me? Thanks.
Last edited by FrdFrmBrdn; 03-19-2012 at 12:17 AM. Reason: added more custom options to help find out what it is
Former Vendor
Drilled rotors came with Z51 and F55 suspension cars in 07. So... if the rotors are original OEM and you don't have the little Sport/Touring **** in front of the center console then you have Z51. As others have said... check the RPO codes to verify.
Great post. I looked everywhere, like engine compartment, door jam stickers, etc. Who knew all I needed to do was to look inside the glove box.
It seems that all those three character codes on the glove box sticker identifies all the features on the car. And so, there it was in the last row of codes, it showed 3LT.
Could not be easier to locate.
Call the local GM dealership parts department with the last 8 digits of the V.I.N.. Don’t even have to have the car in front of you to know which trim you’re looking at buying.
St. Jude Donor '11-'12-'13, '15, '16-'17-'18-'19
