Cost of Harmonic Balancer install?
Old 05-14-2014, 10:17 AM
sjducharme
4th Gear
sjducharme's Avatar
Anyone actually know the quickest easiest way to replace the harmonic balancer on 06 C6. By these posts no real answers other then a few LOL's with no answers of how it was done for 150.00 Seems to me the motor mounts could be loosened and jack the motor up a few inches and the balancer will clear the rack. The GM method calls for dismantling and dropping the rack etc. and other components. Thanks, and I'm not laughing!
Old 05-27-2014, 11:35 PM
SteveC68
SteveC68's Avatar
If you do a few searches you should come up with a guy in Austin TX that can do the install pretty quickly. He has a lift and if I remember correctly it was a couple hour job. I did mine myself in my garage without a lift. I bought the Powerbond balancer for $100. It took pretty much all day Saturday and about an hour and a half on Sunday. I did make about a half dozen trips to the store to buy some tools that I didn't have. The balancer puller I rented wouldn't work so I cut down a long drill bit for that. Had to but a set of line wrenches for the power steering pump lines and cut the line wrench in half. If I had to do it again I could probably cut 3+ hours off the time, but you are still talking most of a day.
Old 05-27-2014, 11:56 PM
torquetube
torquetube's Avatar
I did more or less what you're talking about. I held the engine in place and lowered the subframe with the rack attached. That goes pretty quickly.
Access is still a hassle when working on the ground. This job would go much quicker with a lift.
Quick Reply: Cost of Harmonic Balancer install?
