**AT LAST!** An affordable coil over conversion
Premium Supporting Vendor
Hello Everyone
I am pleased to announce that GMPARTSHOUSE.com is now a QA1 distributor! With that said we can offer you amazing prices on an high quality coil over system that is built in the USA.
These also now have FREE SHIPPING to the 48 states! (The website will charge shipping but we will adjust it off once we process the order)
and to make the deal even better . . . .
If you find a cheaper shipped price we will not only match it but will beat it by 10% of the difference! Email me at patrick@gmpartshouse.com for this offer
Corvette C5/C6 Single Adjustable Pro Coil System
Single Adjustable Suspension Designed Specifically for your C5/C6 Corvette
Simultaneously adjust your compression and rebound with QA1's Corvette C5/C6 Single Adjustable Pro Coil System.
•Made in the U.S.A.
•Easy, Bolt-In Installation
•No Cutting or Welding
•Coil-Over
•Ride Height Adjustable
•100% Dyno Tested and Serialized
•Rebuildable and Revalveable by the QA1 Factory or QA1 Authorized Service Centers
•Kit Will Lower the Vehicle
Prices
Single adjustable
Front pair 489.95
Rear pair 569.95
Front and rear set 1029.95
Double adjustable
Front pair 659.99
Rear Pair 749.99
Racing
Front set 529.99
To order simply give us a call or you can order online here
Also available double adjustable and racing configuations
please email me at patrick@gmpartshouse.com for pricing
•Made in the U.S.A.
•Coil-Over
Prices
Single adjustable
Front pair 489.95
Rear pair 569.95
Double adjustable
Front pair 659.99
Rear Pair 749.99
Racing
Front set 529.99
__________________
Patrick Trageser
CULTRAG Performance
Your one stop source featuring the true experts for all GM Parts and Accessories, Lloyd mats, SLP Performance and Hawk Brake pads!
Order Your GM Parts at www.CULTRAGfactoryparts.com
patrick@cultragperformance.com
1-484-334-8833
CULTRAG Performance
1-484-334-8833
St. Jude Donor '11-'12-'13-'14
That is exciting. Do you guys have the weight of the coilover system? There's little to no weight savings from removing the leaf springs, but I'd hate to see that these add additional weight to the car.
Yes I do front set weighs 16.5lbs -19.5lbs depending on spring rate and rear set weighs 14lbs -16.5 lbs
^ indeed. Especially given you can see Z51 suspension and recoup a good portion of the expense of the coilovers.
Patrick, does QA1 offer a drag-race setup for guys like me who daily drive their cars, but also frequent the track? I'd love the idea of rolling around on coilovers and adjusting them at the track, then adjust them back and drive home.
Is this a true standalone coilover setup or an adjustable shock with a spring that just replaces the stock shock (and still uses the stock leaf spring)?
Last bullet says it will lower the vehicle. As Justin mentioned look at the shock/thread design. It clearly allows for adjustments.
I can't imagine it being anything other than a traditional coilover system. Leaf springs will be removed, this will replace the existing shocks and provide a single adjustment at the shock, and also ride height adjustment via the spring dial.
^ same. If these are good quality, they will definitely sell. (PS, a small part of me hopes it'll bring the price of Pfadts down too )
There was at least one coilover setup on the market that retains the stock leaf springs and replaces the stock shock with an adjustable coilover.
I hope that's what they actually mean and that it's not that the whole assembly is 'shorter' or something?
As in, one can still run the stock (or higher) ride height even with these installed if desired.
The info on the QA1 web site says:
Note: This coil-over system will lower the Corvette at least 1.5” lower than stock. Not designed for stock ride height.
http://www.qa1.net/qa1_motorsports/d...er-shocks.html
Z//
Z//
