DIY seat grommet install
Track Junky
I found a way to have the best of both worlds... Keep the stock C6 seat which retains the power features, airbags, and lumbar support while being able to use a 6 point harness safely on the track. This will provide that middle ground for the members who aren't ready to convert to a race seat yet but still enjoy the track.
Here's an attempt to take a picture journal of the seat grommet install I did yesterday. The pics are on the passenger seat but is identical for the driver seat as well. I'm skipping the info regarding seat R&R since the info can be found elsewhere.
The grommets are from a Viper ACR. Part numbers are as follows:
Front half - 5179161AA
Rear half - 5179162AA
The total cost is about $65 shipped from any Dodge/Mopar website.
Start with seat out of car. Remove back pad. Push in and slide up.
The two clips will release and you will end up with this.
Next, remove the plastic piece on the seat back. Use extreme caution as the plastic clips break easily. I slid a flat head screwdriver underneath to wiggle loose.
Unzip the rear. It helps if you loop a zip tie in the zipper head for future use.
Next, remove the two 10mm bolts on the side airbag if equipped. Be very careful with airbag module. You are only removing the white nylon from around the module. Reinstall airbag back in bracket once nylon removed.
Next, the two front metal bars that run on the edges of the remaining leather. Pic of the back, The bars need to be slid up so the clip portion released then wiggled out of the hole in the seat fiberglass.
Remove the upper leather and you have this. There are about 10 of those christmas tree things that will need to be removed.
Remove the foam piece. 2 more push inserts on the back of the head.
Set rear bezel against and draw outline. The final holes will be much large, but this is a good starting point. The "order of magnitude" initial cut. A dremel tool works very well.
Now time to slowly open up holes using the rear bezel as your template. Keep going until the rear is within 1/4-1/2" of being flush with seat fiberglass.
Note that the release cables will need to be moved towards the center of the seat. Don't worry, they will still work fine.
Next, reinstall the foam and cut. Be sure to start the hole small. The foam should fit the bezel snug. If possible, try to angle the foam cut so the bezel is angled slightly upwards when looking at it (front face sits just lower that rear face. I managed to cut perfectly level, and feel that it would be a better fit if the foam cut was 3-5 degree slope up from front to rear. See how the top lip pinched the foam in just a hair?
Reinstall leather cover. Now time for the nerve racking part...Cut your leather! Use your fingers to feel where the foam has been cut away underneath and cut a horizontal line about 1" short of each edge. Then angle cut to within 1/2" of the corners. Do NOT over cut! Test fit over and over until the front bezel just fits in, You only have one chance to get this right...
Do the same for the rear. When the halves are fit in the leather cuts, snap them together in the seat. You will notice that the seat contour and the bezel shape aren't a perfect match. Use the foam that you cut away as filler. I cut into 1" strips and stuffed around the gaps to fill in. The front looks like it came from the factory. The rear isn't perfect but you won't notice once it's back in the car. I suppose you could buy some additional high density foam from a craft store to make it perfect.
Reinstall leather, and lumbar.
There may be easier ways to do this, and stuffing more foam will certainly fill out all leather wrinkles and gaps.
Hope this helps. Total cost? About $65 and 2-3 hours of work.
Sean
Sean
Track Junky
I have them extended all the way and run them between the top and seat portions of the chair. So basically, you sit on the sub straps and they loop around through your crotch to clip into the cam lock. The Vette Works harness mount works well with this setup.
I like this better than routing around the front of the seat. That option really doesn't prevent submarining at all in an impact. The method above is nice and snug.
Track Junky
I think there are a pair of these mounts for sale in the autox/RR section for $100 each. Otherwise, check this out. $150 new
http://www.c5racer.com/catalog/corve...1997-2012.html
Track Junky
Sean, Nice write up. Question? Doesn't cutting up the seat pan near the headrest make the headrest weak? Wouldn't this modification reduce injury protection to the head and neck in the event of a rear end collision? Just wondering if you had thought of that?
Track Junky
Yeah, I did think of that for a bit before cutting. After the first one, I did a quick comparison between the modified one and stock one by pushing back on the headrest portion - not much difference that I could see. Now I'm 100% positive that there is some loss of strength but most of it is carried in the edges that are folded at a 90* to the seat back. Strength increases as a cubed term in that respect. I initially thought of attaching some form of reinforcement between the holes that were cut or along the sides, but chose not to. With the harness bar behind the seat, it can't go back much (about 3-4").
Track Junky
Track Junky
Thanks for taking the time.
Track Junky
Joe, I'm extremely flattered that you think so highly of my abilities here on the forum. I'm not sure I would qualify as a Tech Contributor... I learn most of my stuff through trial and error, not the years of schooling I suffered through.
Thank you, that made my day!
Folks like you (and of course many others who contribute what they've learned) make the Forum great.
Oh and don't sell yourself short...how many people swap their engine in their garage, or travel 8 hours to help a forum buddy swap his clutch...you're a 1%'er!!
Track Junky
Thanks man. If you decide to give it a try, let me know nf I'll give you my number in case you have questions.
The problem I've noticed is that I go off on a project and take crappy pics during the process which leads to an ok write-up. I should plan on documenting my projects better so others can have good info, not crappy pics...
