I have been searching but could not really find the answer to what I am looking for.
I have an 08 z51 6mt with just a Corsa catback.
I love the exhaust but I prefer a much quieter ride.
I've been thinking of just putting a stock exhaust back on and adding a pair of long tubes, cam, and tune.
Does anybody here know from experience what a stock catback LS3 with long tubes sound like? I'd imagine it would only be marginally louder than stock since the stock mufflers will mute it quite well? This would be perfect for me.
More importantly, how much power will I be leaving on the table with a stock catback with a cam/headers/tune set up on pump gas?
I know catback exhausts in general add sound more than anything, but this stops being true past a certain power level.
You can go back to the stock catback and the car will quiet down. However, when you add headers it will get a little louder and when you add a cam, believe it or not, it will get a little louder again. Heck, I'd go with the headers and cam and then put on the dual mode exhaust with a controller that allows you to open and close them. You get the best of both worlds. Loud when you want it and quiet when you want that.
I had a 2008 Coupe,LS3 with a 6 spd and Z51 options. Also had a GM 'Hot Cam' installed. The factory exhaust was not much louder nor was there interior drone with that set up. You could feel the additional power. The headers were 1 7/8" long tubes from Billy Boat Exhaust. I added a Billy Boat X-pipe with cats and Bullet mufflers. All B&B products are top quality.
I'm sure you already understand but just in case. If you add long tube headers you will not be able to use the stock cats and H-pipe, only the stock overaxle exhaust will remain.
But LT headers, midpipes (especially catted), cam and tune with the stock overaxle exhaust will be more quiet then what you have now. The stock mufflers will not hold much power back at all, maybe a very minimal amount. What I assume what sounds like what you're looking for is; a cam of your liking, 1 7/8" long tube headers w/ catted 3" X-pipe and the stock overaxle exhaust. This will give a substantial power increase and it will be louder then stock but not by much. Also, you could add a pair of electric cut-outs to the aftermarket collection pipes right before the stock overaxle exhaust if you so desire.
To the OP. That's exactly what I plan to do, so thanks for creating this thread. Another thing I'll like to add is that unless you have the z06 oem over the axle muffler you won't be able to use 3" h or x pipe. I think that the base muffler connection would have to be modified since they're 2 1/2".
There are some aftermarket 3" x-pipes that reduce down to connect to the the stock 2 1/2" overaxle exhaust???
Actually, the LS3 on the 2008 has an X pipe, not an H pipe. And the B&B longtubes will fit directly to the factory X pipe (if you don't want to run cats) and the factory cat backs
If I had a LS3, I would go for a complete Z06 exhaust; the manifolds complete to the bi-mode mufflers.
I have been reading up on this for the past 2 hours instead of working - it seems like the Z06 full exhaust is giving up about 40% of power to a set of long tube headers?
OP, basically the route to take for the best power output and the quieter sound you want, that I know of, would be a set of long tubes and a 3" catted x-pipe (since they're mandatory in your case) to connect to the stock overaxle exhaust. Throw in some electric cut-outs before the stock mufflers if you think there will be moments where you want the car to be loud as sin. It'll sound sweet with a healthy cam and really wake up in the power department.
I have the ARH 1 7/8" headers with 3 inch catted xpipe on my 011 GS that has the factory NPP on it. When the valves are closed its just a little bit louder than when it was stock. Still very quiet. If quiet is what you want then you'll be happy with the stock exhaust.
I have the stock catback with LG headers and x-pipe (with hi-flow cats) on my '08. It is slightly louder than stock, but not that noticeable during normal driving. Under WOT, it is louder. It is quieter than an aftermarket cat-back with stock exhaust manifolds, with much better performance.
I've seen claims from vendors on this site of their catback adding 10hp but never any proof to back it up.
I know of a few tuners who have done hundreds or more tunes on cars and bikes, and they have said that cats or no, make very little difference to almost unmeasurable in HP on a tune with almost any vehicle they have seen.
I run stock mufflers with heads and cam, and open my QTP cutouts when I want to sound mean.
I get 6 rwhp more with cutouts open vs closed when I was cam only (perhaps more now that I have heads) so I can confirm the stock mufflers aren't much of a restriction at all.
The stock mufflers are perfect for my daily drive. The car appears like stock until I open the cutouts, then it bellows.
Here is my thread with pics and sound clip if you are interested. I did this before the factory NPP came out. Cutouts sound much deeper than the NPP but sound is a personal preference.
Had QTP cutouts installed by Florida Performance in Fort Lauderdale. Overall very pleased with the job Rob, the shop owner, did. This was his first C6 and he found a great place to put them and made the custom mandrel bent Y-pipes to maximize flow from the cutouts. We found no way to put them right after the collectors but they fit well by the trans. I have the DTE brace too but it wasn't in the way.
Installed the wiring myself along the drivers side rocker panel, behind seat then out the wheel well under the carpet. Removed the rear inner fender and drilled a small hole in the wheel well then ran the wire down to the cutouts. Hardest part is finding a hot wire when the ignition is on on these C6's. I ended up tapping the seat heater fuse as others here have done.
They are loud and DEEP when open at idle. I've actually heard louder exhaust though, I was kind of surprised they are not louder. I think it is because of the turn downs and the fact that I have cats and the pipes are pretty long before the cutouts. On the track they have a nice race car sound - I'd say like Borla Stingers plus 25%. When you open them at a stoplight you will turn heads, that's for sure.
Overall happy with the mod, it gives me quiet during my morning drive but loud when I'm at the track which is what I wanted.
Here is a video of idle with cutouts open and closed. The gain on the mike makes the closed sound much louder than it is, it's really quiet with factory mufflers even with my cam.
