Which clock spring / part nr should i order..?
Hi guys.!
Im sorry if my spelling is bad but Swedish is my native language. =)
I have a 2005 C6 and in my car is the very ugly 4-spoked steering wheel.
I have after months of searching got myself the airbag for the newer 3-spoked steering wheel and will order the centennial Steering wheel soon.
I now understand that the clock spring is different from the 2005 and 2006 years and must be changed to get the airbag and horn to work but i also read somewhere that there is different colors on the wiring from 2006 to 2008 i think.
I was wondering which clock spring i should order to fit the centennial sw without having to change connectors or rewire things. Hope someone can provide me with the correct part nr.
I know the centennial sw have buttons for radio etc but i do not care if they work just want the plugs and wires to be correct for the airbag and horn to work.
Appreciate your help
// Peter
// Peter
I just found out the gm part nr for the newer clock spring is 19153097
I looked at different vendors and it seems it cost about 150$. That was rather expensive in my opinion.
Maybe someone have one to sell..?
Could i use the 2006 clock spring with the newer steering wheel since im not going to have functional buttons for radio and BT..? Just want the airbag and horn hooked up. =)
Does anyone know the part number for the 2006 clock spring..? Need it so i can maybe find one on Ebay etc. If someone have one for sale then please contact me. =)
Best Regards
Peter
Best Regards
Peter
sending you a PM which shows information you will find usefull. sending 6 links, for 2005 2006 2009 for both telescopingpower and non telescoping
sending pm
sending pm
Thanks alot for your help ChevyDave..!!
As you showed they it should fit also 2005 but everywhere i read they ones who have updated their sw from 2005 to 2006 or newer sw had to change the clock spring to make it work.
It seems in a reply in a thread i found that it seems like the connectors to the airbag are different. Look at second post in this thread
http://forums.corvetteforum.com/audi...l-on-06-a.html
Maybe i could modify the connectors on the 2005 clock spring or solder them on or something. =)
Dont have all the parts yet so its hard to know before that but it would be nice to save about 200$ if i could. =)
Thank you again..!
// Peter
Thank you again..!
// Peter
For future reference if someone asks about the part numbers for the different clock springs then here they are. =)
2005 clock spring part nr: 89060632
2006 & 2007 clock spring part nr: 19133742
2007 ------> clock spring part nr: 19153097
This information was provided by ChevyDave.!
