LS7 Map Sensor Replacement
Old Mar 18, 2013 | 09:09 AM
TwinDmax's Avatar
TwinDmax
Default LS7 Map Sensor Replacement
07Z06 just purchased and will finally drive it for the first time today; however, I was told the MAP sensor was bad. The car has 13k and I was told it runs fine.
Does anyone have any pointers for checking before I take the intake off? Does anyone have the GM procedure for this task?
Old Mar 18, 2013 | 10:26 AM
truckplay's Avatar
truckplay
it is on top of the intake, 5 minutes. is the engine stock ? Fast ? read the codes 1st and check for vac. leaks.
Old Mar 18, 2013 | 11:36 AM
cclive's Avatar
cclive
Not sure who told you, but the check engine light should be illuminated. Check the codes yourself before changing anything. Also, if the code shows, check connections before replacing anything.
Old Mar 18, 2013 | 11:41 AM
TwinDmax's Avatar
TwinDmax
My dad has it and said the comp. shows map. The car has a MTI stage 2 cam, ported heads and tune. Other than that, it has a borla catback. I heard the sensor was under the intake and took roughly 4hrs.
My flight comes in at night and I will go right to work. Also, the cel is on.
Old Mar 18, 2013 | 01:40 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
The Manifold Absolute Pressure sensor is on TOP of the manifold!
Old Mar 18, 2013 | 02:55 PM
TwinDmax's Avatar
TwinDmax
Is it only on top for the ls7's?
Old Mar 18, 2013 | 07:08 PM
chimazo's Avatar
chimazo
Nope, it's on top for the LS3, too. Red thing in pic below, although yours will be black.
Old Mar 18, 2013 | 09:35 PM
TwinDmax's Avatar
TwinDmax
My dad said p0106 and changed the sensor with no luck. I will look at it soon; plane just landed.
Old Mar 21, 2013 | 08:14 AM
TwinDmax's Avatar
TwinDmax
okay, just changed the map but as we were working on it the "real" problem presented itself; dropped valve
Old Mar 21, 2013 | 09:49 AM
erick_e's Avatar
erick_e
St. Jude Donor '13-'14-'15-'16
You say "dropped valve".
Did you mean broken valve, or did the valve actually drop?
EDIT: Never mind, I saw your other thread. The amount of these valves breaking are becoming ridiculous.
Old Mar 21, 2013 | 09:55 AM
TwinDmax's Avatar
TwinDmax
yeah, I just came back from Afg. and the car was running "rough" right before I got home; I still have yet to drive it...
My dad and I were troubleshooting what we thought was the "intermittent" CEL from the MAP b/c that's what the guy said was wrong when I had my dad pick it up. I told my dad to beat on it a little and he got it up to 135 before buying it and driving it back from AR to AZ. The car made it back with zero problems and the next day, my dad didn't even make it a block. He is 67 and doesn't beat on cars and always drives decent as well as warms up vehicles before driving.
Fortunately, he had a Suburban that he was able to sell me and I just picked up a trailer yesterday. I wanted to "drive" the car from AZ to GA where I live but I just didn't think it would be on a trailer. I may decide to post up a few status's as I drive across hwy 10 to see if anyone wants to meet up along the way.
To LS7 Map Sensor Replacement
