TFS 225 and G6X3 install (finally)
Old 05-04-2013, 12:10 PM
JayplaySS2
JayplaySS2's Avatar
Default TFS 225 and G6X3 install (finally)
I'm going to post a ton of pics for you guys-
This took longer than I thought it would since I have been so busy with work and a 3yr old
A HUGE thanks to Brian Tooley!!
Thank you Spin and a few of you here namely ITS STOCK and Neumonic2002. Thank you guys-
Here they are out of the box. Brian port matched the FAST to the heads and did a stellar job THANK YOU Brian
The heads are the 225's and they are at 61cc with BTR spring retainer kit and 3/8 7.5 push rods using stock rockers. Very tight fit but they do work- I am runing stock MLS gaskets and the rockers are stock for now but I will upgrade to trunion kit when I can aford it. The 7.5 (3/8) push rods with stock rockers at 61cc and stock GM gaskets give me a total of 1.5 turns after zero fwiw-
Enjoy-
Done-
Vengeance wil be retuning it in a few weeks.We'll see what it does. Think I'm done for a while, except for the trunion upgrade. Car runs very well-
Wondering if I should keep the Vararam spacer on?
Old 05-04-2013, 12:25 PM
Joe_G
Joe_G's Avatar
St. Jude Donor '08
Looking forward to the dyno sheets and track times!
Be sure and get the .drf files so you can overlay your dyno sheets so we can see the exact effect of the heads over the powerband.
Boy those are really a work of art.
Old 05-04-2013, 12:39 PM
ITS STOCK
ITS STOCK's Avatar
Your gonna love it. When the cam hits around 3500 it just throws you in the seat.
Old 05-04-2013, 01:05 PM
DSOM
DSOM's Avatar
I can't wait to hear how this turns out. I have a set of TEA 215's waiting to go on a new short block being built.
Old 05-04-2013, 01:13 PM
Joe_G
Joe_G's Avatar
St. Jude Donor '08
Here's my AFR head dyno sheet (actually all my mods overlaid). We can see how much better the vaunted TF's are when Jay posts up his sheet. If you get the .drf files and are intersted, send them to me and I'll overlay your dyno sheet on mine so we can see the differences between the G5x3/AFR 205 combo and the G6x3/TF 225 combo throughout the rev range.
BTW my AFR's are 59cc and I put on a .045 gasket if I recall...my CR is around 11.8 and I can only run about 22 degrees of timing at torque peak.
Old 05-04-2013, 09:51 PM
peter pan
Life Time NCM #2196
Support Corvetteforum!
peter pan's Avatar
Received 1,099 Likes on 810 Posts
Nice set of heads and looking forward to the results
Old 05-04-2013, 10:24 PM
old motorhead
old motorhead's Avatar
Received 1,339 Likes on 947 Posts
Savannah makes the rest of all that stuff look better! Beautiful!!!
Old 05-05-2013, 01:04 AM
JayplaySS2
JayplaySS2's Avatar
Yes sir, the tune is a little off from the head swap but on street tires it's no use anyway.
Thank you sir-
Joe- I'll get the same graph from Vengeance overlayed from the EPS cam/AI heads, then G6X3/AI heads and now the TFS/G6X3.
It will be a few weeks though
Old 05-05-2013, 08:22 AM
C U IN REARVEIW
C U IN REARVEIW's Avatar
Glad to hear its done,been waiting to hear the results. Congrats!
Old 05-05-2013, 08:25 AM
Joe_G
Joe_G's Avatar
St. Jude Donor '08
Thank you sir-
Cool. Get the .drf files too, let's overlay my g5x3 to your g6x3 (both of us with stock heads and FAST) and we will see the difference - to my knowledge, that comparison hasn't been overlaid on a dyno sheet so that'll be cool to see.
Old 05-05-2013, 01:21 PM
TLTONEY
TLTONEY's Avatar
WOW!! They look awesome!
Old 05-05-2013, 09:39 PM
Gering
Tolero Apto Victum
Gering's Avatar
Also the FAST is a great mod for an LS2 - http://forums.corvetteforum.com/c6-t...st-intake.html
Old 05-06-2013, 12:14 PM
All_Motor_C5LS6
All_Motor_C5LS6's Avatar
Subscribing for results
Old 05-06-2013, 01:24 PM
FloydSummerOf68
FloydSummerOf68's Avatar
Good luck with the results you want
Old 05-09-2013, 04:49 PM
0Anthony @ LGMotorsports
Former Vendor
Anthony @ LGMotorsports's Avatar
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13
JoeG just turned me onto your build.
Can't wait to see the results with the new heads!
Old 05-09-2013, 05:02 PM
Joe_G
Joe_G's Avatar
St. Jude Donor '08
He's on phase 2...
http://forums.corvetteforum.com/c6-t...l-finally.html
Gonna knock me down a rung on the 1/4 mile fast list I'm sure.
But good for him, what a great build and Jayplay is really good about helping other Forum members with advice.
Old 05-09-2013, 05:40 PM
huggerorange73
huggerorange73's Avatar
St. Jude Donor '12-'13
Awesome stuff right here
Waiting on the numbers!
To TFS 225 and G6X3 install (finally)
Old 05-16-2013, 12:41 PM
30th T/A
30th T/A's Avatar
In for the results!
Old 05-16-2013, 01:42 PM
mowe
mowe's Avatar
In for dyno numbers...
Old 05-16-2013, 08:30 PM
bmfvette
bmfvette's Avatar
If it wasn't for Savannah, this would be a ho-hum build...Cant wait to see the numbers!
Quick Reply: TFS 225 and G6X3 install (finally)
