Clutch/Shifting Issue
Hello All:
I am having some issues with my 2006 M6 Corvette Coupe. It has the Z51 package if that makes a difference. 23,500 miles on the clock. I purchased the car about 3 months ago and have put 1500 miles on in that time. I daily drive this car about 10 miles per day. The past week I have been noticing some issues when shifting.
The most noticeable thing is that when I attempt to downshift, I am getting very noticeable resistance when I try to shift into the lower gear. My usual downshift method is to do a throttle blip with the clutch held in, and then let the clutch out once I get it in gear. Since this problem started, I have tried double clutching and seen some definite improvement in getting it to go in gear.
The second issue, that has only happened to me twice, is that I will go to shift to the next higher gear, and the shifter will be "stuck" in gear, even with the clutch held all the way to the floor. After a couple seconds of coasting, I am able to pull it out without using much muscle.
The final thing I have noticed, which may or may not be in my head, is that when shifting in general, I feel like there is just a bit more resistance and a bit more of a "metal-on-metal" feel in the shifts, both up and down.
My suspicion is that the clutch is not fully disengaging when I push the clutch in. Does this sound correct? I have been reading about the "ranger method" of clutch fluid flushing and im wondering if this would alleviate my problem. If not, does anyone have any other ideas? Or should I just take it in to the dealer. I do have an extended warranty on the car.
Thanks for your help.
Former Vendor
Defiantly start by changing the clutch fluid. That usually helps in most cases. If your issue still occurs and you have a warranty to cover it then take it in to be fixed.
If your warranty does not cover it then feel free to give us a call if we are close to you. We change clutches in c5's and c6's on a weekly basis and can get you taken care of.
OK, a bump and a follow up question. My mom works for the local chevy dealer, so I asked her to pick up a pint of brake/clutch fluid while at work today. I wrote down the part number that is given in the owners manual (88958860) and wrote that it is for a 2006 Corvette on the note. She gave the note to the parts guy, and he sent her home with a pint of DOT3 brake/clutch fluid, part 19299818. My manual specifically says to use "Super DOT-4" brake fluid.
I am assuming there is a difference between DOT3 and DOT4 brake fluid, and that there is a reason the manual calls for the DOT4. Should I use this or should I take it back and hold out for the DOT4 stuff. Is it possible they don't keep it on hand or that the tech made a mistake? Or are they used interchangeably?
Dot 3 or Dot 4....
For the clutch in a C6 use Dot 4 only. Do not mix or put dot 3 in....Good Luck.........
You can get brake fluid for a lot less at a parts store ......
THe only difference is DOT4 has a higher boiling point, which prevents the fluid from boiling and introducing air in the system. It's pretty cheap, so I'd get DOT4 just to be on the safe side, but you can mix them without any issues in an 'emergency'. Even Walmart carries it (Prestone).
SUBVETTE
You can find it at Walmart for minimum cost. If the Ranger method flushing doesn't help, the bushings in your shifter box may be shot, which is fairly common with a car of your age. They deteriorate from heat with age causing shifting problems. A new shifter box may be needed. If you are handy, it can be a DIY project with a new box going for about $150 from GM parts suppliers on the forum.
